Old 04-05-2011, 08:42 PM   #21
El_supracabra
El_supracabra is on a distinguished road
ouch.... LOL
anyways...
I dont ever remember saying "my cams dont line up"....because they do. perfectly. I triple checked my valve timing, AND my ignition timing.
I really dont appreciate "my88isgreat" implying that I didnt "read the book".
so.... not to mention that he said "gates racing is in on it too" does that mean they built your engine for you? cuz i built mine all by myself.
Thanks CRE for the useful information. I swapped out the fuel pump relay and resistor with another one and it didnt change anything. I also put a jumper wire on the TPS connector and checked my fuel cut. according to the TSRM (that i actually read ;-) my fuel cut should be at 1800 then return at 1200. My actual fuel cut is at about 2400 and returns at about 1900. This is actually the only thing i can find "wrong" with the car.
advice?
oh and how do you bypass the relay? by connecting a jumper between +B and PR on the fuel pump relay connector? thanks!!
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 04-05-2011, 10:25 PM   #22
My88isGREAT
My88isGREAT's Avatar
My88isGREAT is on a distinguished road
Yes they did! thanks for asking!
I don't even own a car, just here for the moral support and friendly people. The Dr. said its good for me. Have a supra day!!
My88isGREAT is offline   Reply With Quote
Old 06-04-2022, 05:49 PM   #23
pishta
pishta is on a distinguished road
The 7mge is a non interferance motor to begin with, so no. The only thing it will do is raise the compression a bit.
Wrong...the cam timing will be retarded because the cam cog will be closer to the crank cog and will roll CCW a smidge. You can only mill an OHC about .02mm before you need to cut and use a "head saver" shim. these are usually .020" an allow a .020 cut on the head or block to preserve factory valve timing.
pishta is offline   Reply With Quote
Old 06-04-2022, 07:18 PM   #24
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Here are some photos of a uncut and a cut head. The more you cut a head the flatter that rounded part under the thermostat standpipe connection gets. It's something to look for when buying a head. I had my head and block resurfaced and ended up using an old school metal shim gasket under the Toyota factory gasket. I sprayed the bottom of the shim gasket That contacts the block with Prematex copper spray. After 7 years and 35K miles, I haven't had any issues. Alternatively, you could use a thicker stacked metal head gasket alone but you really need to prepare the surfaces first. Here is a link to a company that can supply most any thickness of shim gasket you want. I wouldn't go of more than 0.040" though. It's been discussed in other forums that a 0.020" cut is a small fraction of a degree out of timing. The Toyota manual allows 0.010 but doesn't say anything more than that.
Innovative machine & supply: https://innomach.com/cylinder-head-shims
ID:	5066   Click image for larger version
Old 06-06-2022, 03:03 AM   #25
WOW! Resurrected after over 11 YEARS!?!
Best Cylinder Head Seal Supra Saiyan MKIII Supra 5 02-06-2011 01:10 AM
torque settings for big end shells and cylinder head johnkarl MKIII Supra 4 11-03-2006 04:01 PM
Cylinder Head?? ZauggIt1 MKIII Supra 8 10-24-2006 01:51 AM
Valve Job On Head Now Car Wont Start? MKIII shujin MKIII Supra 4 08-07-2006 02:16 AM
