Old 03-23-2011, 09:47 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Yes. Chances are your knock sensor themselves are not bad. Most likely the wiring to the ecu from the knock sensor its a real common problem and pretty easy to do.
Here is a good link
http://www.supras.com/06/techcenter/display.php?QID=69
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Rod Knock! OR is IT? Rob1 MKIII Supra 5 03-02-2011 12:26 AM
Knock Sensor/Wiring MarkLinRacing MKIII Supra 2 03-23-2010 02:52 PM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
