Old 03-03-2011, 05:37 AM   #21
Sonyps307
You can get the Flywheel bolts and folk at driftmotion.com. And you might want to replace the front and rear seals of the tranny. I got both my new motor and clutch all in and come to find out they where both old, dried up and leaking on my w58.
Old 03-03-2011, 06:01 AM   #22
The rear seal on the engine. As far as the clutch side goes you need: flywheel, clutch disc, pressure plate, throwout bearing and pilot bearing.... just trying to help prevent you from forgetting something.
Old 03-03-2011, 09:11 AM   #23
ochowdero
seal?
what you mean ?
i know what a seal is, but i dont know exactly what your talking about tho.
i really want turbo
Old 03-03-2011, 09:13 AM   #24
ochowdero
i also have the hardline that goes from the master to the slave cylinder, and the soft line from the slave connecting to the hardline..
is that it or did i miss something?
i really want turbo
Old 03-03-2011, 11:12 PM   #25
Sonyps307
I'm talking about the seal for the out put shaft and the seal where The drive shaft goes they r cheap and easy to replace.
Old 03-04-2011, 12:18 AM   #26
ochowdero
is it in the tsrm so i can read more about it?
i really want turbo
Old 03-04-2011, 12:45 AM   #27
http://www.cygnusx1.net/Supra/Librar...ection=MT&P=34
http://www.cygnusx1.net/Supra/Librar...ection=MT&P=33
Old 03-04-2011, 06:45 AM   #28
ochowdero
sweet thanks,
btw im taking my automatic shifter out and theres a green plugg that doesnt disconnect... how do i get it off?
this plug connects to the power button and somewhere on the tranny
i really want turbo
Old 03-04-2011, 07:00 AM   #29
ochowdero
my list is in my signature,
what else do i need?
the u-joint?
and what else?
i really want turbo
Old 03-04-2011, 08:29 AM   #30
ochowdero
hey cre, im getting all the miscellaneous parts together,
in a previous post you mentioned fasteners from toyota..
what fasteners so i can get em while i look for stick shift and pedals
i really want turbo
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
