Old 01-27-2011, 12:15 PM   #1
StillChasing1
StillChasing1 is on a distinguished road
Unhappy Multiple problems 7M-GE
I recently returned from a deployment and pulled my car out of storage.
I started it up and it ran just fine (with the exception of a rough idle) right up until it got warmed up completely.
i have massive power loss, the exhaust turned beat red from cat #2 back to the muffler, and it is having serious idle issues.
I drropped the cat thinking that was a problem but it was in perfect condition.
I tried timing it but i cant get it into perfect time, i am not sure if im missing something here but i set it TDC and hit it with a timing gun get really close but every few times around the notch jumps and comes back. What could cause this and is the timing issue causing the problem with the exhaust?
StillChasing1 is offline   Reply With Quote
Old 01-27-2011, 05:38 PM   #2
When timing it did you remember to set the diagnostic jumper? Have you tried dropping the #2 cat and the piping behind it and running the engine? Any difference? How long has it been sitting? Have you added any fresh fuel or gasoline stabilizer?
Here are the details on setting the timing: http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=18
Old 01-27-2011, 10:36 PM   #3
StillChasing1
Yes I did jump it, a friend of mine has a diagnostic tool with a timing setting do you think that might help?
Dropped #2 cat and started car still ran rough, loud as hell and actually a quite pleasing sound, then after about 5 minutes it died.
It was sitting for about 6 months and I added 2 gallons of gas and fuel treatment when I picked it up but thats it. do you think adding more fresh fuel would help?
And if that doesnt work what else could it be?
Old 01-27-2011, 11:14 PM   #4
Fresh fuel is always the first thing wo start with when coming back to a stored vehicle. Are there any diagnostic codes stored in the ECU? No, no diagnostic tool does much of anything with these cars except for a certain advanced diagnostic tool which Toyota used to make... only available through them for a few grand, naturally; You can find out just as much with a piece of wire and a multimeter.... and a book. Some tools come with adapters for this type of system but their results are usually so far off and so bizarre I really wonder where they got their info.
Old 01-28-2011, 12:50 AM   #5
StillChasing1
No codes are popping thats whats driving me insane!
Old 01-28-2011, 02:51 AM   #6
Purge the old fuel and put in a couple gallons of 89 octane. Run that for a bit and see if it starts to clear up.
Old 02-22-2011, 12:43 AM   #7
Piggy808
Piggy808 is on a distinguished road
Hey...im a pretty cheap guy when it comes to gas...so i run up 87 at the pump with 10% ethanol...i havent seen anywhere else that doesnt say 10%...anyways...its always bogged and the timing setting was at about 12 degrees Advanced from TDC...thats when i got the car...I advanced it to about 16 degrees cuz im a noob at this kind of stuff and i guess i got the gear on wrong for the distributor and could only retard it to about 15 degrees...anyways the car ran pretty darn good...burnin rubber and stuff.
A few days ago i decided that i should try and put the distributor on right and the timing back to 10 degrees like the manual says. and its back to bogging at the lower rpms at the factory settings. So a few days of bogging and I decide that maybe the crank marking is wrong and I rather want it to run like before, so as im going through the process of adjusting the distributor gear to advance it a bit...some dude comes out and ask me about my supra. To make a long story short, he had the same problem and it cleared right up when he changed to buying the 92 gas for fuel. and to be honest, i did what he said, ran the gas out...then filled it with 92, and the car seems to run better.
My questions are: Is the 7mge meant to run 92 only? What about the stuff i mentioned earlier about running at 15 degrees plus advanced, and running fine with 87? I happen to get free gas but only 87...thats why im asking. Thanks for reading through and any helpful comments are much apreciated.
Piggy808 is offline   Reply With Quote
Old 02-22-2011, 02:19 AM   #8
The GE is actually spec'd for higher octane than the GTE... So 87 for the GTE and 91 for the GE or around there... altitude, ambient air temp and humidity all play a part in determining what octane is best for your situation. I ran 87 in my GE but only because I'm a mile above sea level and the air is thinner. The difference in price between mid grade and high grade (when it's not free of course) is only a couple dollars per full tank... it's cheap insurance. BUT, also to keep in mind is that the higher the octane the less power it makes per unit.
Advancing the ignition timing (the spark advance, not the same as the mechanical timing) accomplishes very little. The ECU will push the timing as far forward as its ignition maps allow... this is allot further than the 6? you've advanced it... and once it detects knock it'll retard it until the knock is gone. There will be a bit of a difference when the car is cold and running in open loop (not the time when you want to push the engine too hard), but once up to temp it's back in the ECU's hands.
The ECU adjusts timing for knock and ping, but knock due to detonation isn't something that adjusting timing is going to help with... the fuel is exploding versus burning at a predictable rate and in a predictable pattern.
My recommendations to you are to use come Mopar combustion chamber cleaner to get the pistons and valves nice and clean and then to use a GOOD octane booster. I'm assuming you've got plenty of humid, but I know you've got plenty of heat too. Also, get the mechanical timing sorted out and get the ignition timing in check; It should be 10? BTDC.
EDIT: I should mention that fuel octane grades vary by region.... here we have 85 as the lowest, 87 mid and 91 high... this is M+R/2, there are a couple different standards for rating octane, the US uses the two methods averaged. I know in some places in the US 87 is the lowest and 93 or 94 is the highest with 89 in the middle; This is generally in the higher temp and drier climates.
Old 02-22-2011, 03:53 AM   #9
Piggy808
Thanks for the info! So check mechanical timing too? so the distributor timing advance does nothing that the ecu cant adjust...so, why do you think it ran better when I had it at 16 degrees advanced? Also about the octane booster...87 plus..lets say a good octane booster...that will be sufficient for fuel? I gotta take advantage of my free 87 gas situation . As for cleaning out the pistons and stuff...I did what nickleeye suggested in a post...used some carb cleaner into a vacuum and just ran it a bit. seems to work.
Im at sea lvl, 60% plus RH, and a heck a lot of heat...sucks to be in hawaii right now. Im practically in a sauna over here. The timing is set back to 10 degrees. But i havent fully experimented with running the 92 gas yet.
Old 02-22-2011, 06:01 AM   #10
Everything you're saying here makes me think the timing is off... either the mechanical timing is off or you're not properly setting the ignition timing. It's also possible that you are squeezing a little more power out of it but not safely... Don't run at any significant advance without higher octane fuel, it's begging for a rebuild. Yes, the ECU tries to pull ignition advance if knock is present, but it can only ever pull or add so much, you're shortening the systems safety net.
If you want to stick with your free fuel you gotta be willing to toss in $10 of toluene with each tank. Remember, the octane booster ALWAYS goes in the tank BEFORE the fuel; That way it gets properly mixed in.
I prefer MCC, a bit nastier. For a thorough clean you may pull the spark plugs and spray in a good amount and let it sit overnight; Just spray in enough to fill the piston domes. Most of it should be evaporated by the next afternoon and it will be hard to start after you put the plugs back in.
Tags
7mge, exhaust, power loss, timing
Distributor problems? ekoston69 MKIII Supra 1 02-02-2006 11:29 PM
