Old 11-29-2010, 01:53 PM   #11
are you losing fluid??
sounds like a leak if the pedal doe's not come back on its own.
when my master went i could build up pressure by pumping the pedal and it was enough to stop, the O-rings inside the cylinder went bad overtime.
this is like day 4 of your post its time to bleed the freakin brakes!!!
thus narrowing down your search for what is wrong...
Old 11-30-2010, 12:42 AM   #12
xAimz
xAimz is on a distinguished road
Thumbs down
Ive been bleeding the brakes for 2 days now... at first BLACK fluid was comming out with dirt in it..... (confused) kept doing it, and it started to clear up, ima do it tomorrow some more to, but the pedal is still spongy and i have to pump twice to stop. so ima keep bleeding till the fluid is clear. and then im going to replace the master cylinder
xAimz is offline   Reply With Quote
Old 11-30-2010, 04:38 AM   #13
Good idea. Even if the bleeding doesn't fix it, new brake fluid is definitely better than old
Old 11-30-2010, 07:28 PM   #14
xAimz
yeah.... i hope its the MC, if not then im screwed
Old 11-30-2010, 08:44 PM   #15
Ranma
Ranma's Avatar
Buy a new one, gee
Old 11-30-2010, 11:12 PM   #16
xAimz
Originally Posted by Ranma View Post
Buy a new one, gee
<< wants to bleed brake first, so all the old black fluid comes out
brakes dont work in cold weather bassboy3313 MKIII Supra 4 11-21-2010 10:12 PM
MKIII body work help bradenman1 MKIII Supra 8 10-10-2010 02:34 PM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
13 inch Wilwood MKIII front brakes ARZ Arizona Performance 0 03-16-2007 07:57 AM
