Old 10-29-2010, 08:51 AM   #1
cfurlan
cfurlan is on a distinguished road
Default Does anyone know where these wires go?
I started putting my engine back together and came across this set of wires taped together and my label got smeared and I cannot read it. It's on the driver's side below the intake. Any help would be great, Thanks
cfurlan is offline   Reply With Quote
Old 10-29-2010, 01:10 PM   #2
im assuming there coming from your wiring harness that runs between upper and lower intake plenum. should just go around bolts for the upper plenum, there just grounds.
i had the same problem a few months back:
http://www.toyota-supra.info/forums/...2-starter.html
Old 10-29-2010, 07:48 PM   #3
Sonyps307
They bolt to the lower intake pipes they r the main grounds to ur ecu and starter I forgot on my build also and I put the in the wrong place and I had no spark so had to bolt them to the intake
Old 10-30-2010, 04:53 AM   #4
cfurlan
Hey thanks for all your help. I will be completing the finishing touches on my motor tomorrow...trans mount, driveshaft, intake, and wiring. So I will keep everyone posted and let you guys know how my rebuild went.
Ignition Wires SideWinderGX MKIII Supra 10 07-19-2007 08:44 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
Igniter Wires PORADA2005 MKIII Supra 0 05-01-2006 08:18 PM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
loose wires 87supraturbo19 MKIII Supra 10 01-19-2006 05:51 PM
