Alright, i am totally stuck on this. What is the easiest way to find a vaccume leak in a gte motor. i cant pass emisions until i fix it and thats what they say the problem is. Also is there any way to lean out the fuel and air because i failed that test too because they say that my car is running to rich. I have like seven days to fix it becfore my license is suspended. Please help!
(1988 Supra with Gte swap) |
get some carby cleaner/engine start
spray everywhere on your intercooler pipes and intake manifold and vacuum lines.. everywhere like that when you spray somewhere and your idle goes up then you have found your leak
are you throwing some codes ?
check engine light going off for a little bit . i slipped into running very rich a few months ago , it turned out to be vsv switches located under the intake one is for egr and the other for fuel . they are easy to test but hard to get to . you'll see under the intake a mess of small black hoses going to and from two brown and black little things about 2.5 inches or so see here: http://www.cygnusx1.net/supra/librar...10/1708_3.html part# 25860 and 17650 the EGR is # 25860 just check for continuity . zero = toast . i use an air/fuel gauge so it's very easy to spot variances in the mixure from screwing around with mods . i am not saying this is your problem it's just another option to try . another option is to adjust the base idle screw what does it idle at now ?
my tach doesnt work yet because i motor swapped so if i had to guess i would say it is idling around 500. and yes my engine light comes on intermintently. where is that air fuel adjust screw you were talking about?
#5 | |
#6 |
More than likely it's a boost leak, in other words a leak anywhere after the turbo. That's a lot of pipes, and a lot to check, but it's not too hard to find. You can make a PVC pipe with a cap on it that will fit in the intake so you cna pressurize the system with the car off and listen for leaks. If you can hear it but can't find em, use the old trick they use on tires, soapy water sprayed in the general area with bubble up with the leak.
If it's not this...if could be leaky injectors, but the pipes on the intercooler, ect go out sooner, so it's a safe bet that's where the problem is... |
#7 |
Idle at 5? hmm
| Heater Union (Coolant Leak) | slader99 | MKIII Supra | 11 | 12-28-2009 12:29 AM |
| Oil Leak. | supramacist | MKIII Supra | 0 | 05-01-2008 01:18 AM |
| Coolant Leak | bossman | MKIII Supra | 2 | 04-12-2008 09:31 PM |
| Oil Leak Question | kidsusukigsxr | Non-Generation Specific Questions | 2 | 06-26-2007 03:17 PM |
| gas tank leak | burton51m | MKIII Supra | 14 | 11-24-2006 06:16 PM |
