Old 08-19-2010, 06:59 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Exclamation Timing/CPS = ?No start?
Sorry Cre, didn't realize I was posting in the FAQ before. So I made my question on the appropriate section..
Originally Posted by Bill UK View Post
Locate the CPS with the cam pulleys as sown below, assuming you have already re-installed the can belt with the crank pulley set at zero (# 1 piston at top dead centre) and cam pulleys as in photo. Line up the hole and notch as marked with the red arrow on the CPS and insert into the head. You may find when the gear engages with camshaft helical gear the CPS shaft will rotate, I removing mine a few times to double check it hadn’t moved before nipping up the adjusting bolt. Its also worth replacing the O ring Toyota part # 90099-14018
018
~MY QUESTION BELOW~
Can the CPS cause a no start if it is not lined up as shown above?? To dive into more detail to the no start I am talking about. I mean cause it to do everything except turn over.. you know.. That point when your car is trying and trying and trying to kick over but, just keeps trying.. Ends up with nothing.. That moment right before starting..
Again, CAN the CPS not being lined up as shown above cause it to not turn over..?
Supra Saiyan is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
