Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 11-13-2009, 11:06 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Locate the CPS with the cam pulleys as sown below, assuming you have already re-installed the can belt with the crank pulley set at zero (# 1 piston at top dead centre) and cam pulleys as in photo. Line up the hole and notch as marked with the red arrow on the CPS and insert into the head. You may find when the gear engages with camshaft helical gear the CPS shaft will rotate, I removing mine a few times to double check it hadn’t moved before nipping up the adjusting bolt. Its also worth replacing the O ring Toyota part # 90099-14018
018
HTML code is On
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
Setting the timing?? Dejvid1785 MKIII Supra 0 02-16-2006 04:12 AM
Standard /static Timing setting WilliamBodie MKIII Supra 6 12-08-2005 11:35 AM
