#11 |
If it sat that long and was just periodically turned on and then back off there could be a significant amount of damage from condensation: Pitted cylinder walls and eroded bearings.... just something to keep in mind. Was this still driven on weekends or just sitting in a garage for 5 years? At any rate, if you've got experience with rebuilding and plan on doing so it's no big deal.
#12 |
oo belive me i just droped alot of money on hourse power freaks, bottom to top rebuild! but i did have a question should i get a ruber HG or a metal one? and what kind of pistions? and any one know were i can get a High VOL Water pump? and any one know the size of the belt needed with out AC! and whats a good cam set up? i have found alot just wondering what worked the best for people if you tryed out a few. and after market heads? do they even exist???????? sure have found alot of cat backs tho ahah! http://www.horsepowerfreaks.com/part..._Touring/10112
has any one messed with that exaust? |
#13 |
hahah its funny the more looking i do the more shit i find i forgot to order!! such as a bushing main kit! break lines big break kit! ahahah its starting to add up, Total is now at 5476.87 car not included! oo and as i was looking around any one know a sight for trans rebuild kit and/or trans gears?
#14 |
Rubber HG? WTF are you talking about? Where on Earth did you hear of rubber head gaskets??? Your choices are: composite (like the stock one; single layer of metal as a substrate for compressed graphite), copper (generally only used in racing applications) and multi layer steel (MLS generally what is being referred to as a "metal HG"). MLS, steel shims and even some copper HGs vome with a VERY thin viton coating to act as a sealant, but this doesn't justify the title of "rubber HG".
#15 |
Aha I'll post the link when I get home it was on eBay. I was thinking the same thing.
#16 |
Only two possibilities: 1) joke/novelty 2) they're fucking retarded
#17 |
My guess is a retard!!!
#18 |
But to go back to your question, the man said it was started every weeke d and drove around the block. For 10 mins and basic shit was done.
#19 |
If your going to rebuild the motor from top to bottom why not convert it to a NA-T. If your looking for cams the best bang for you dollar would be to buy a set of 7mgte cams and put them in your head. Oh and buy a metal head gasket and ARP head studs
#20 | |
There is NO difference in the GTE and GE exhaust cams. The only difference is a VERY small change in duration vs lift. GE intake cams on the GTE make it fall flat on its ass in the mid RPM and remains there. Running a GTE cam in the GE costs the N/A pretty heavily. You lose a very big amount of bottom end power and the N/A doesn't flow enough to make up for it (as the GTE does starting around 2K RPM). The GTE intake cam is a worthless upgrade... well, downgrade actually.
| 1987 Toyota Supra MKIII 350 Chevy / 700R4 Project Car | Vacationtime247 | Show n Tell | 4 | 06-04-2009 03:53 AM |
| HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
| Mark II Engine Swap Questions | nightshade I | MKII Supra | 1 | 06-30-2006 05:01 PM |
| Cant find chip for 1987 supra turbo | adellicson | MKIII Supra | 0 | 05-08-2006 03:27 AM |
| Mark IV Twin Turbo Engine in a Mark II ('86) | snowbor444 | MKII Supra | 6 | 06-15-2005 01:39 AM |
