Old 07-05-2010, 09:37 PM   #1
Conga1991
Conga1991 is on a distinguished road
Default doing a 7mgte swap, have a few questions
what would be the best oil to break my engine in the firt 500 miles? next 2000 miles? how much transmission fluid do I need? what would be the best kind?
Im not going to be using the egr system, what do I do with the vsv and vaccuum lines that go under the intake to the p.s. pump? Also will it mess with the ECU?
And last the wiring harness, I notice there are a set of plugs that go under the intake side inbetween the intake manifold where do they go? I couldn't find any ports to plug them in. ill post pics of the plugs in a bit.
Thanks for your inputs.
Conga1991 is offline   Reply With Quote
Old 07-05-2010, 11:27 PM   #2
Get a JDM ECU.
Old 07-06-2010, 12:03 AM   #3
Conga1991
for what? not using the egr
Old 07-06-2010, 12:26 AM   #4
Yup. Or add a fuel controller, run open loop full time and tune the engine to run a little richer at cruise.
Old 07-06-2010, 02:10 AM   #5
Conga1991
what you said was a bunch of giberish. also on the ecu I have it has a plug coming out, what plugs into it? I couldnt find a port for it to go into. (I have a 88 NA body and the Motor is a 87 7mgte same as the M/T ECU)
Old 07-06-2010, 02:16 AM   #6
batmmannn
batmmannn's Avatar
Default Gibberish?
What Cre says is never Gibberish, but I understand how you feel. I have to do research sometimes to keep up with Cre. You have to read what he says and then race to catch up by reading info about what he is trying to tell you. Cre has told me things that overload my capacity of knowledge and then I do keyword searches and research terms and functions to understand what he is telling me. You have to do some of the work yourself to learn the abbreviations and the systems he is talking about. Upload a pic of the areas you have questions about so we can see what you are talking about. This is the easiest way.
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
2JZ GTE Swap questions geli MKIV Supra 4 09-09-2009 01:43 AM
7mgte Swap SilverBullet05 MKIII Supra 3 07-17-2008 12:18 AM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
