Old 04-18-2010, 04:42 PM   #1
crzy-mk3
crzy-mk3 is on a distinguished road
Default problems
I have an 87 mk3 7mge motor blow up. i swapped an 7mgte into it n it is not gettin fire now what to do.
crzy-mk3 is offline   Reply With Quote
Old 04-19-2010, 12:00 AM   #2
Start with checking error codes.
Old 04-19-2010, 01:03 PM   #3
first i assume this 7mgte was running....
get a flashlight and start looking at EVERYTHING make sure its all hooked up there is alot of cables and wires and hoses to reconnect
Old 04-19-2010, 01:31 PM   #4
crzy-mk3
thanks will check all wires n hoses. will get back to u on that.
Old 04-20-2010, 02:11 AM   #5
Krem
are you getting spark at all? if so, try adjust your timing... if not... at least you know which end of the elec system you need to focus attention on. Also, did you get a new ECU with the turbo? 7mge != 7mgte on several different levels... including compression ratio..
Old 04-20-2010, 02:52 AM   #6
not to mention exhaust would have to be changed...
as well as many others,
but he said he had an N/A and says nothing about a gte conversion
it is nice to hear the whole story....
Old 04-20-2010, 08:19 AM   #7
Krem
He did mention he went from 7mge to 7mgte swap... so conversion was done... what was included on the 7mgte and what was missing vs process and procedure maintained and followed during the swap is anyone's guess...
Old 04-20-2010, 01:53 PM   #8
crzy-mk3
i have power to the coil and distributor but no spark. i changed ECU and harness but still no spark
Old 04-21-2010, 12:28 AM   #9
Which are you running the GE electronics and harnesses or the GTE electronics and harnesses? They're NOT mix and match.
Old 04-22-2010, 02:51 PM   #10
crzy-mk3
i am running the GTE ECU and harness with GE head with distributor. i swapped intake manifold, throttle body.
random dying problems (1989 n/a) thechori MKIII Supra 11 11-06-2006 05:03 AM
