Old 03-31-2010, 11:18 PM   #11
scaggsj
scaggsj's Avatar
Actually its not as bad when the engines cold, it kinda seems to get worse after its warmed up. Holds temp though. Useally a little below half way mark I keep coolant in it other wise it probley would be overheating. Im pretty sure the coolant is only getting in while its running. The water level dosent go down after its been sitting. Only after you run it.
1987 Supra 7MGE - Auto - Stock - White
Previoius Toyotas;
1992 Toyota Celica Gt, (Sold)
1988 Toyota Celica Alltrac Turbo (Died)
Old 04-10-2010, 03:27 AM   #12
scaggsj
scaggsj's Avatar
Still having the same problems Ive quit driving for now guess Im going to have to tear into it and figure this out. Anyone know if there are any passages that I should check that could be leaking coolant into the cyls? Im going to start by pulling plugs to find out which ones are burning it and then go from there any suggestions will be appreciated
Previoius Toyotas;
Old 04-10-2010, 08:54 PM   #13
I would suggest renting a rad pressure tester or go buy one for 60 bucks from harbor freight. pressure the rad system according to the psi on the rad cap (13 max) and see what sprays!
good luck
since your gonna be pulling crap apart.. do it the ez way
Old 04-12-2010, 10:16 PM   #14
scaggsj
scaggsj's Avatar
Ill see if the local parts store has one for rent. I thought you were saying to test the cap. I shouldve read it better. I knew the cap was good cause I just put it on. Im really hoping its not the Headgasket again. I think if it is rather than spend the time and money doing this again Im going to go the 2jz I found a place here in Florida that says they have jdm 2jzgtes with an auto trans mission and no cut lines with ecu and stuff for 2280.
Previoius Toyotas;
Old 04-13-2010, 12:00 AM   #15
wow. if you have the pocket change go for it.. I wouldn't pass it up. if it was in working order.
Coolant on top of spark plugs suprajim MKIII Supra 3 03-24-2010 03:49 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
coolant plugs suck balls tone loc MKIII Supra 4 08-13-2006 09:29 PM
