Old 03-19-2010, 01:56 AM   #1
Which engine? 1G-GTE, 1JZ-GTE or 2JZ-GTE? In all of these cases I believe the airflow is determined through the measuring of manifold pressure via a vacuum hose... in which case btwilson86 is dead right, a bad vacuum hose is a very likely culprit.
Old 03-19-2010, 02:16 AM   #2
rohin02
rohin02's Avatar
rohin02 is on a distinguished road
Okay thank you i will get my mechanic to check it out this is a 1jz GTE engine.
rohin02 is offline   Reply With Quote
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
turbo 3 idle, vsv advice wesbam1 MKIII Supra 1 05-10-2006 08:07 PM
