Old 02-24-2010, 02:31 AM   #1
coulter894
coulter894 is on a distinguished road
Default safc question
This may be a dumb question but I will ask it anyways, I have an apexi v-afc2 from a friend. Can I use this in place of a s-afc2 and just not use the v-tec portion or will that not work. This is for my 90 supra with the 7mgte. Thanks for any input that may help
coulter894 is offline   Reply With Quote
Old 02-24-2010, 04:25 AM   #2
Post a link to the PDF of the instruction manual and I'll look it over... I'm inclined to say no, but that would be nothing more than a guess. I think the one thing it's going to really come down to is if the VAFC supports KVAFMs.
Old 02-25-2010, 05:56 AM   #3
coulter894
sorry not exactly sure how to do that, I found the instructions on the apexi website under the support heading.What should I be looking for and I will see if I can find it. Thanks for your help.
Old 02-25-2010, 07:43 AM   #4
I dug up the manuals.
I could speculate about the compatibility but the fact is that the published documentation doesn't provide enough information to draw any hard conclusions. You could try powering the unit up and looking through the menus for the settings specified for the SAFC II... that's where I'd start.
SAFC II User's Manual http://www.apexi-usa.com/content/pdf6118.pdf
VAFC II User's Manual http://www.apexi-usa.com/content/pdf6132.pdf
Apex'i Wiring Diagrams and Manuals http://www.apexi-usa.com/info/?id=5383
Old 02-26-2010, 04:09 AM   #5
coulter894
I will do that, thanks for the help.
1990 supra with 7mgte. Lexus afm,550 injectors, k&n filter system, aftermarket exhaust,greddy boost controller on stock ct-26 blowing 14 psi.
Old 02-26-2010, 04:57 PM   #6
Green7mgte
Supra Forum Moderator
if worse comes to worse. sell it on ebay then turn around and buy a safcII.
im running an safc1 if its any consolation. broader tuning points but fairly ezier interface.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
apexi safc? map ecu? west_side_supra MKIII Supra 8 12-21-2007 07:48 AM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
