Old 01-25-2010, 12:22 AM   #41
bradenman1
bradenman1 is on a distinguished road
Originally Posted by Benesesso View Post
You already have the valve covers off, so get a GOOD torque wrench and check the head bolt torque. IIRC, stock bolts should be good for ~72 ft. lb., far better than the original 58. Take a good look at a bolt head and see if it says SPS or ARP. Those are aftermarket bolts and will take a little more.
Are the head bolts the big 18mm hex bolts in the spark plug area??
bradenman1 is offline   Reply With Quote
Old 01-25-2010, 01:03 AM   #42
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
No, they are 10 mm socket head "capscrews"--there are 14 of them. You can buy a 1/2" drive metric socket with a male 10mm section, or just buy a 1/2" 6 point metric socket in 10 mm and a 10 mm Allen wrench. Cut ~3/4"+ off the long end and use that piece.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 01-25-2010, 02:09 AM   #43
bradenman1
do i have to take the intake manifold off to do this?? i didn't look really closely but i didn't see any bolts or anything. if i can do it without taking the intake manifold off i would but that manifold looks like hell to get through and id rather not go through it right now lol
Old 01-25-2010, 02:31 AM   #44
Benesesso
Benesesso's Avatar
No, but I think you have to pull the cams. They're easy, and you should install a new cam drive belt then too. Do a 'net search on how you have to line up the marks on the cam pulleys--it's no big deal.
Old 01-25-2010, 03:51 PM   #45
bradenman1
I may have to do that.. just more time I have to wait and more money to spend : ( I'm still in school andwork every day other than Sunday ill have to wait a few more weeks to get the cam belt and a torque wrench
Old 01-25-2010, 04:28 PM   #46
bradenman1
Old 01-25-2010, 06:08 PM   #47
Depending on the size of the socket you may be able to tighten the head bolts without pulling the cams, you'll just need to turn them periodically to let the socket clear. I've done it a couple times.
When you torque the head bolts down remember to do it in multiple passes and also make sure to loosen any head bolts which are not already loose by backing them off 1/4 to 1/2 turn.
Old 01-25-2010, 07:54 PM   #48
bradenman1
Post
Ill have to take a look at them tonight I guess. You said to re torque them to 75 ft/lbs.
Old 01-25-2010, 07:57 PM   #49
bradenman1
Ohh I have another question. Is there a tool I need to get to install the new exhaust manifold studs to safely get them in without damaging the threads? Or should I just use the two nut method and try to torque them to 29 ft/lbs
Old 01-25-2010, 09:58 PM   #50
I've only ever replaced two studs... if you're going to have problems it will be with the threads themselves. Do your best to get the studs seated as well as possible, but don't worry about torquing the studs by themselves.
Information about non turbo Supra Jimbo_2JZ Non-Generation Specific Questions 3 02-20-2009 10:13 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
HorsepowerFreaks Turbo M3 vs Single Turbo Supra ChrisB Non-Generation Specific Questions 0 01-01-2007 04:56 PM
