Old 08-18-2005, 02:41 PM   #1
Makavelli
Makavelli is on a distinguished road
Hey experts, here's one for ya
This mornin when I fired up the Sup, as I backed outta the garage I heard a sound that resembled water bubbling under the hood. Don't know if this is related, but when I first got in the car I thought it smelled funky, like mildew or wet carpet. I figured maybe I was imagining it, but then I hear the water noise, so I dunno.
Yesterday I had 2 temp spikes. One after getting gas, when I turned on the engine. Though it didn't reach HOT, the temp guage went to about 3 quarters to the top. On the way home yesterday, for no reason while driving in bumper to bumper traffic, the temp guage went to just over halfway. (It normally sits at a bout a quarter) then went back to normal.
Is my car possesed by gremlins?
<span style='font-size:14pt;line-height:100%'>Stock...for now</span>
Makavelli is offline   Reply With Quote
Old 08-18-2005, 04:23 PM   #2
Skyer
Skyer is on a distinguished road
my car also sounds like rushing bubbles under the dash, but no mildew odor nor heat spikes. I was told that it has something to do with the hoses for the heater or something like that. there's two pipes at the back of the engine, one on the left, and another on the right, one has to be plugged can't remember which one.
I do have another problem with the cooling system, I sometimes build up pressure inside the water system? but the head gasket seems to be in mint condition.....
Who knows..... old cars gotta love them
Skyer is offline   Reply With Quote
Old 08-18-2005, 04:55 PM   #3
Makavelli
Some have suggested BHG, but hell I just had it checked 2 weeks ago and it came out sqeeky clean...
Old 08-18-2005, 04:56 PM   #4
Intenseneal
Guest
Posts: n/a
The sound you are hearing might be the start of a blown head gasket my car make the same sound
Old 08-18-2005, 05:08 PM   #5
SuperSupra86
SuperSupra86 is on a distinguished road
well my first guess would be seepy head gastket....my second would be replacing hoses in the cooling system...air has got to be coming from somewhere...their maybe a leak...maybe get some dye that shows leaks
Who needs zoom zoom......I got turbo!!!
SuperSupra86 is offline   Reply With Quote
Old 08-18-2005, 07:39 PM   #6
daiagaru2
daiagaru2 is on a distinguished road
could be,bad thermostat,bad hg,bad rad,bad heater core lines,if gremlins existed they'd probly do alot more damage than that.good luck
daiagaru2 is offline   Reply With Quote
Old 08-18-2005, 07:54 PM   #7
supra887mgte
supra887mgte is on a distinguished road
those stoupid ggremlins hey u need to put mayonase in ur intake tube itll definetally solve the gremlins
supra887mgte is offline   Reply With Quote
Old 08-18-2005, 10:48 PM   #8
Poodles
If you smelled something, you probably have a heater core with a leak, or a heater core hose leaking. If it's draining while sitting, then getting filled again while running, you're also going to go low on coolant. Could be a BHG, as they are known to go quick too...
Old 08-19-2005, 12:07 PM   #9
^ thankyou hehee
yeps.. low on water for bubbling in the dash (you need to top up and burp)
bubbling and smelly inside sounds like heater core leaking
Old 08-19-2005, 04:11 PM   #10
Makavelli
Originally posted by suprra_girl@Aug 19 2005, 12:07 PM
^ thankyou hehee
Would that make it run hot? Yesterday, it started to run hotter again. Not OVERHEAT, so much as just hotter than normal. Normally she runs in the 1/4 mark, yesterday she got as high as 3/4 at one point. When it's moving, the temp goes back to normal, but when its sitting, it rises (albeit very slowy).
I've never heard a fan kick on, does this thing have one?
Noise From The Trunk Help krupt_01 MKIV Supra 1 02-19-2009 10:47 AM
Weird noise from rear trevor510 MKIII Supra 2 02-23-2008 08:46 PM
unknown noise hkssupra MKIII Supra 5 09-22-2007 11:59 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
