Old 01-04-2010, 02:59 AM   #181
EDIT: I am sorry... I re-read the thread and this was a rebuild.... I'm getting confused from one member to the next this past month. My apologies.
Here's some excellent information on breaking it all in: http://www.supramania.com/forums/showthread.php?t=48993
Sorry Joe, I'm an ass.
Old 01-07-2010, 08:51 AM   #182
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
hahaha yup yup rebuild. anyways so i was so frustrated with the car. and its numerous amounts of leaks.....
so i took it all apart. hahaha in one night. i start worl in 5.3 hours. grrrr i better hurry
cvbikeguy is offline   Reply With Quote
Old 01-07-2010, 06:44 PM   #183
cvbikeguy
cvbikeguy's Avatar
Where in the engine should I or should not use rtv suff. (Gasket goop)
Old 01-12-2010, 02:00 AM   #184
cvbikeguy
cvbikeguy's Avatar
im still alive.....
car isnt.
so i have everything fine and perfect.....
except a leak underneath the intake runner (that tiny nipple i was trying to find before. but it actually doesnt look like its coming from the hose. looks like coolant is leaking from where the intake runner and the engine head meet..... im so lost. this will be the 4 time taking everything apart. any ideas?
thanks
Old 01-12-2010, 02:16 AM   #185
The coolant channel passes through the runner's flange and into the head. If the gasket is damaged or poorly sealing it will leak.
Old 01-12-2010, 03:34 AM   #186
oregonjoe
oregonjoe's Avatar
Default Water Through Intake Runner
Yup - true as rain. That magic nipple under the intake runner feeds right through to the head and if the gasket is not right - will leak. I RTV every place where coolant can leak. .
Also don't forget about the coolant bypass that goes up to the throttle body as well
RTV the Intake runner on both sides where the collant passes through, Rtv all coolant hoses
No leaks yet,
Old 01-12-2010, 03:38 AM   #187
cvbikeguy
cvbikeguy's Avatar
"You don't need to rtv that"
Last time I listen to a guy with an evo also...
Grr
Old 01-12-2010, 03:40 AM   #188
Excellent! Thanks for the pics Joe!
One thing to note is that if the gasket has a viton coating for that passage you need to be very careful about any sealants you might want to use on them... most contain enough trace solvents to cause the viton to bubble or ripple and may actually cause a worse leak than allowing the viton to do its job. If there is no sealant present, then YES, a thin coat of RTV is the way to go. I've had both types of gaskets in the past and neither leaked... never tried one with no sealant.
Old 01-13-2010, 02:22 AM   #189
cvbikeguy
cvbikeguy's Avatar
ahouls i be worried about the coolant getting in places it shouldnt since it leaked?
and yes thanks so much for the pics and help. im not giving up yet....
after putting this together for the 4th time?
Old 01-13-2010, 02:37 AM   #190
Well, as long as it isn't pooling up anywhere you should be alright. Make sure it's hanging out with the spark plugs in the galley.
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
