Old 01-03-2010, 12:35 PM   #11
Originally Posted by cvbikeguy View Post
bolts moved smoothly all the way. used the goooooooooy stuff they gave me. did it in 3 passes also to make sure everything was tight.
Okay... I'm just the paranoid sort; It's served me well over the years.
*turn key*
rev rev rev rev..... POP
smoke........
sorry folks but this maybe be it. maybe its shop time
Well, don't blame ya if you do, but I'd go over it all one more time... you're missing something. If it's back firing through the intake either the mechanical timing is off or the plug wires are installed in the wrong order.... same thing's likely if it's doing it out the back too actually.
I'd go back through the TRSM's reinstallation segment and double check everything. http://www.cygnusx1.net/Supra/Librar....aspx?S=EM&P=1
Make sure you do not over tighten the timing belt tensioner pulley, it will distort the #1 cylinder rather easily if tightened past specs.
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
