Old 11-16-2009, 10:01 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Bolt pattern PCD 5 x 114.3mm Offset 35mm-38mm Centre Bore 60 mm The larger the offset the more the wheel will sit under the wheel arch.. The stock saw-blade wheels are 37 offset. I did have a set of MK4 5 spoke with 50 and 45 offset not only did they look wrong I found the steering very twitchy. I now run with 18 x 8.5 Front and 18 x 9.5 Rears, offset 35mm. What ever you decide; make sure you have the correct bore or order the correct spigot rings. 60.10mm will fit perfect.
MK3 spare wheel fits TT MK4 car? (can a TT take a 16X7 rim) TONY! MKIV Supra 3 03-20-2007 09:10 PM
1987 ga70 wheel offset nightreaper Non-Generation Specific Questions 2 02-12-2007 08:45 AM
19 inch wheel offset on 94 t/t hks94twinturbo Non-Generation Specific Questions 0 11-05-2006 03:23 PM
Wheel Offset and Width for MK3 Dijkstra Non-Generation Specific Questions 1 02-27-2005 07:44 AM
