Old 07-09-2009, 03:29 AM   #1
JoshUsherwood
JoshUsherwood is on a distinguished road
Default power steering noise
my power steering shows very obvious signs that its leaking, and it makes loud annoying noises when i turn the wheel. its also kinda hard to turn when its not moving. i know that its going out, but i was wondering, why bother with it and i want to just eliminate it. what do i need to do to get rid of it. it'd also help cool the turbo as its directly in front of the turbo.
JoshUsherwood is offline   Reply With Quote
Old 07-09-2009, 10:24 PM   #2
mk3teen
mk3teen's Avatar
mk3teen is on a distinguished road
very nice, its a sweet fender in my opinion, someone mentioned a tranny, is tht the one that comes on the turbomodel. i found a junked 87 turbo standard. i would love to do a swap, automatic just isnt for supra's.
mk3teen is offline   Reply With Quote
Old 07-17-2009, 01:54 AM   #3
JoshUsherwood
bump. no ones really replied.
is there like a kit to get rid of the power steering?
Old 07-18-2009, 02:42 PM   #4
carl johansson
carl johansson is on a distinguished road
don't know specifically on the supra - but there are lots of aftermarket solutions. You could just take the rack and run the hoses so it's a closed loop - then remove the PS pump - but then you will need a new set of pulleys to route the belt.
Kind of hard to turn when it's not running? thats what it will be like all the time if you eliminate it.
ps pumps are cheap - 50 - 100 bucks at any autoparts store. To eliminate the PS - you are probably looking at 250 - 600 bucks to do it right - add another 200 if you plan on replacing the actual rack!
Carl Johansson
carl johansson is offline   Reply With Quote
Old 07-20-2009, 11:49 PM   #5
samabhi111
samabhi111 is on a distinguished road
I am not sure but I think you should change it now.
Toyota Supra 2004 Toyota Headlights
samabhi111 is offline   Reply With Quote
Power Steering?!? Boombastic Drifting 5 05-19-2009 04:19 AM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
