Old 06-10-2009, 11:51 AM   #1
grabber
grabber is on a distinguished road
Default 7MGE ECU problems
I have a 7mge in my 89 runner... For the most part it seems to have run fine for about the last year... On may long it started to sputter a bit at lower rpms and the tach and a couple other gauges went whacky. Now I can hardly drive it it sputters so bad. My check engine light doesn't work either even from the pin at the computer it doesn't ground the wire. My only guess is to try a new ecu. Oh ya it doesn't seem to adjust idle or anything when its cold either. Any ideas?
grabber is offline   Reply With Quote
Old 06-10-2009, 05:23 PM   #2
GettaRobo
GettaRobo is on a distinguished road
You could see if the throttle position sensor is unplugged/not working. I had a similar problem a couple days ago and discovered that my TPS was unplugged a couple days ago and it fixed my wacky tach gauge right up. As for sputtering, I'd check your spark plugs to see if they're firing properly... That's what I'd do, but I'm pretty new to dealing with these engines, so if someone sees something wrong about my advice, feel free to correct me.
GettaRobo is offline   Reply With Quote
Old 06-10-2009, 10:53 PM   #3
grabber
I have adjusted and checked the TPS sensor and its all good, and just replaced everything in the ignition without fixing the problem... Any other ideas?
7mge R154 Manual Trans nnate1228 MKIII Supra 0 03-28-2009 05:59 PM
