Old 05-24-2009, 04:43 AM   #1
darkOmini
darkOmini is on a distinguished road
Default engine problems
i have a 1987 7mge engine with a whole in the block. from throwing a rod. so i went to buy a new engine got it all set in and when i went to hook up the wire harness did not quite match and nobody could tell me why. does anybody no why and how hard would it be to make a conversion or even put in a 2jz? any help would be awesome
darkOmini is offline   Reply With Quote
Old 05-24-2009, 01:18 PM   #2
Dan Swanson
Dan Swanson is on a distinguished road
Default Engine problem
First thing did you buy a 7GME that is the same year as your car. If Not that is probably why you have problem.
I own 1987 Supra with a 7GME engine, I have done som major repairs. But if you are thinking of putting a completely differnt engine in you will have more problems than you have now.
The supra manual has complete wiring diagrams, which should be of help to you.
Dan Swanson is offline   Reply With Quote
Old 05-24-2009, 03:50 PM   #3
darkOmini
they said it was a newer one but they kept telling me that it would make the swap up until the 1992 model yr. if i just swapped the head off my old one to the new block would that solve the problem?
Old 05-29-2010, 10:08 PM   #4
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
If you are talking about the temperatrue sensors around the thermostat housing, you can use or move your old ones. Use a small amount of teflon paste or thin tape. Don't over tighten. Its easy to crack the aluminum here. Even the rear thermostat housing itself unbolts from the block. You will need a new gasket or silicone.
Old 06-06-2010, 03:34 PM   #5
U have no idea why this is in the FAQ (or why Bru is posting replies in a year old thread. LOL). Thread moved to the MKIII section.
Tags
2jz, 7mge, wire harness
Sup Guys, total nub having some engine problems with my MKIII... Mr.Supra857 MKIII Supra 3 11-14-2006 06:37 PM
engine problems thewhitedevil69 MKIII Supra 3 03-07-2006 12:17 PM
Problems With New engine. lilsmitty MKIII Supra 1 10-29-2005 07:43 AM
