Old 10-20-2010, 12:15 AM   #11
zby67
zby67's Avatar
zby67 is on a distinguished road
Originally Posted by kwnate View Post
An exhaust on a NA is not going to net 20hp. .020 overbore is not going to make any noticable difference in power. It will probably feel faster due to the old motor being old and worn out.
what about boring over by .2 or .4 with the 3" exhaust and cold air intake?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
Old 10-20-2010, 02:46 AM   #12
907mge
907mge's Avatar
Do the math and figure out the change in displacement and that should point you in the right direction.
Old 10-20-2010, 03:25 AM   #13
zby67
zby67's Avatar
im really bad a math... and i wouldnt even know ware to start lol...
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 06:00 PM   #14
Grandavi
Grandavi's Avatar
regardless what you do with your NA (unless you make it into a 7MGE-t (thats a turbo addon to a non turbo 7M which I would not recommend) your not going to notice any massive pull increase. Dollar for dollar your better just dropping in a 7mGTE or doing a 1JZ swap.
I have done a ton of reading in this and the 1JZ is the best overall, however the 7MGTE is acceptable as well (and cheaper).
Unless you are going to put it on a track though, you dont need to do massive upgrades. Personally, if I owned a NA, I would do what I could to get it running solid and at peak efficiency, I wouldnt mod the hell out of it. Its not worth it in my mind. Large overbore = large $$ considering you would probably be thinking cams/pistons, etc.. going to cost you more than actually turbo'ing it.
Old 10-20-2010, 08:46 PM   #15
zby67
zby67's Avatar
hmmm the a normal rebuild and just add cams, cold air intake and a new exhaust cause the car needs one anyway. then do body work and if i cant find the 1990 supra im looking for ill go GTE and have fun moding the car for stick. thanks for the info. im just trying to get as much as i can out of the GE was all i was looking for.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-21-2010, 12:18 AM   #16
Grandavi
Grandavi's Avatar
I dont own a NA, so I am typing solely out of research, not personal knowledge. (just so we are clear about that, lol)
Old 10-21-2010, 01:19 AM   #17
Sonyps307
Just build the 7mge to take a huge turbo Or a shot of nos
Old 10-21-2010, 02:19 AM   #18
zby67
zby67's Avatar
thats a nice way to blow the engine or was the the point?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-21-2010, 02:50 AM   #19
Sonyps307
No u will wont blew it if it's build up withe forged parts and arp bolts the stock crank is already forged but I don't know how much hp it can hold safely
Has your question already been asked? mrnickleye MKIV Supra 1 01-07-2010 05:35 PM
1/4 times supra_91 Supra FAQ 1 06-04-2007 03:34 AM
What 0-100 performance times should I get? fiend1 MKIV Supra 0 11-11-2005 03:31 PM
93+ supra NA 1/4 times? triskillion MKIV Supra 2 10-14-2005 09:53 AM
1/4mile times SCRAMJET MKIII Supra 7 09-13-2005 01:33 AM
