Old 05-06-2009, 06:07 AM   #1
dunewarz
dunewarz is on a distinguished road
I would recommend checking the timing first. After 2 days of checking the tps and cleaning the iscv I found out that my timing was off causing the engine to run at high rpm. But I also found out that my iscv was dead so I manually adjusted it to the right position and so far no major problems, just a bit of bogging when you let off the gas and get back on it quick.
dunewarz is offline   Reply With Quote
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Erratic Idle motosparky MKIII Supra 18 06-26-2007 09:35 PM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
