Thread: Erratic Idle
Old 05-06-2009, 06:07 AM   #1
dunewarz
dunewarz is on a distinguished road
I would recommend checking the timing first. After 2 days of checking the tps and cleaning the iscv I found out that my timing was off causing the engine to run at high rpm. But I also found out that my iscv was dead so I manually adjusted it to the right position and so far no major problems, just a bit of bogging when you let off the gas and get back on it quick.
dunewarz is offline   Reply With Quote
