Old 07-27-2005, 09:42 PM   #1
Makavelli
Makavelli is on a distinguished road
Hey guys, is the NA Supra even worth buying? I'd like to turn one I found into a project car, but was wondering if I should go with the NA or the Turbo. Is there really that big a difference? What's the max HP I can get outta an NA???
<span style='font-size:14pt;line-height:100%'>Stock...for now</span>
Makavelli is offline   Reply With Quote
Old 07-28-2005, 12:20 AM   #2
Intenseneal
Guest
Posts: n/a
If you decide on buying the NA and want a turbo I have a stock CT26 turbo manifold and turbo 440cc injectors for sale $80 for everything. As far as is the NA worth buying that is all up to you and what you are looking to get out of the car. The NA motor has a higher compression ratio and with the right tuning has the potental to make more power than the turbo motor dueto the higher compression ratio. But again tuning will be very important to keep the motor alive.
Old 07-28-2005, 03:27 AM   #3
Guest
Guest
Posts: n/a
Power-2-$$ ratio = Turbo is best bet over N/A. Oh, you got $$ to blow?? Then get a MK4 and build it !!
Old 07-28-2005, 01:37 PM   #4
realistically... find a Turbo if at the end of the day you want power
you can get power from an NA but it takes a whole lot more money time and research
and MK3'S ROCK!!!
Old 08-10-2005, 11:56 AM   #5
jono
Guest
Posts: n/a
Yess finaly sumone has said that haliluya i luv mk3's aswell, im going to rac a crx
Old 08-10-2005, 06:42 PM   #6
Makavelli
Still got them parts for sale?
Old 08-10-2005, 11:35 PM   #7
Riddick
Riddick is on a distinguished road
i hear from the grap vine..............oh hell it was in some sport tuner book, that theres a storker kit for the NA engine, that would max the torqure out large, might give a turbo a good run, also makes a 3.0L into a 3.4L
sounds nice to me.
kit has pushrods/pistons and crank, not sure what else comes with it ill have to find the book.
Stroker = Low end torque at a lower RPM's
Turbo = Higher HP and Torque at greater RPM's
ive built many chevs and i think ill try the stroker kit before i turbo my NA.
Riddick is offline   Reply With Quote
Old 08-11-2005, 12:35 AM   #8
Riddick
sorry connecting rods not push rods.........lol
