Old 02-05-2009, 04:38 PM   #1
gamer565
gamer565 is on a distinguished road
Default 87 supra wont start on its own
I did a NA-T swap(7mgte) in my 87 and finally got it to run today, but it needed carburetor cleaner sprayed into the intake tell it could run on its own.
the timing is correct, the fuses are good, theres good fuel pressure, everything is connected correctly. and as far as i know there are no codes being thrown.
i think its the cold start injector, will a 7mge injector work?
gamer565 is offline   Reply With Quote
Old 02-05-2009, 09:16 PM   #2
CyFi6
No, but thats also not going to stop it from starting. Something is not letting the injectors open obviously if you have good fuel pressure and everythign else is good. Use a noid light to check if you are getting power to the injectors
Old 02-06-2009, 02:37 AM   #3
supraduper
supraduper is on a distinguished road
did you install and connect the cam sensor?
doesnt the ignition run off the crank sensor where th fuel injectors run off the cam sensor?
pretty sure... but not positive..
just something else to check
supraduper is offline   Reply With Quote
Old 02-06-2009, 03:48 AM   #4
CyFi6
Thats kind of typical in a modern car but the supra runs the ignition off the cam as well
Old 02-06-2009, 05:13 AM   #5
gamer565
the CSP and timing is all correct..
im gonna check the cold start timing switch tomorrow along with the injector too.
Old 02-07-2009, 11:04 PM   #6
gamer565
Update time
code 51 is the only code that its showing
the CSI is getting a pulse, fuel and the ohms is 3
the cold start injector switch is not getting and power or a pulse, should it be tho?
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
supra wont start tex1116 MKIII Supra 2 10-21-2005 12:54 AM
