Old 07-28-2008, 07:41 PM   #1
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
Default rebuild ct26
well i decided to try and rebuild my ct26 myself. i'm going off the guide from robert pina and i cant get this thing on top of the washer off.
anyone have any tips?
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
Old 07-29-2008, 01:24 AM   #2
paulmicin
paulmicin's Avatar
I also noticed that the washer is different than the one in his guide.
here's a different shot.
Toyota CT26 Rebuild by Robert Pina
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 07-29-2008, 11:28 AM   #3
mkiiisupra
Turbochargers - SupraMania
Perhaps check out that section over at supramania they have a few people over there that have rebuilt these things many times. Sorry cant help more than that
1990 Toyota Supra Turbo A/T
Old 07-29-2008, 12:49 PM   #4
paulmicin
paulmicin's Avatar
well i got it off. all it needed was a little coercing.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 07-30-2008, 04:19 PM   #5
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
I really hope you marked the wheels real good. If they don't go back in exactly the same positions in relation to each other you are screwed and you will need to send it off the be rebalanced.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 08-02-2008, 07:27 PM   #6
paulmicin
paulmicin's Avatar
Well, since i didn't mark the wheel to the shaft it looks like it will have to be balanced. So my question is do i just send in the shaft with the wheels or the whole turbo assembly. Also, where's a good, reasonably priced place, to get this done? And, where can i get a rebuild kit?
Is this compressor wheel still good?
Thanks in advance.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 08-03-2008, 04:45 PM   #7
j3pz
ya you should have sent it in to get rebuilt. even marking the wheels, you have a slim-to-none chance of putting it back balanced as they spin 10k+rpm. google mdcmotorsports or driftmotion, and give them a call. they specialize in mk3's and have rebuilt numerous turbos.
Old 08-03-2008, 09:49 PM   #8
robertsws
robertsws's Avatar
Exclamation
Screw that, that guy doesn't know what he's talking about. I've rebuilt more than one and i've both screwed up the balance on one and i've maintained the balance on one. If you know what you are doing and are extremely careful you will not need to do a rebalance. even a turbo shop will tell you that.
I personaly recommend the gpop shop. they do awesome work and they are quick. they are also very professional. they do charge more than some other shops, but i also know for a fact that some of those other shop do terrible work. the one in indiana for instance, although i can't remember their name.
also a good inexpensive rebuild kit from turbos_r_us on ebay, make sure it's a ct26 kit though.
I'd rebuild the turbo and send it off to the gpop shop and ask them about the wheel. it looks like it will work to me but a professional should look at it. also when you do send it don't send the wheel housings, just the shaft, wheels, etc. to keep your postage down.
Home
479-751-7966
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
To rebuild or not to rebuild that is the question 88supraturbo5speed Non-Generation Specific Questions 6 04-21-2008 04:05 PM
PLEASE help newbee with engine rebuild canadian mole MKIII Supra 4 06-17-2007 01:01 AM
Rebuild or Replace? Supra Guest91SupraTurbo MKIII Supra 7 08-26-2005 04:06 PM
