Old 06-19-2008, 04:10 PM   #1
MWJon
MWJon's Avatar
MWJon is on a distinguished road
Default 1jz cam question
i have a mkIII with a 1jz motor and i was wondering if i could use 2jz cams? thanks
MWJon is offline   Reply With Quote
Old 06-19-2008, 07:19 PM   #2
supradaddy0803
supradaddy0803's Avatar
I am not sure that the 1JZ cams will work. Also depends on what 1JZ you have if it is the VVTI then you are pretty much out of luck. Which cams are you looking at?
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-19-2008, 08:46 PM   #3
MWJon
MWJon's Avatar
im kinda new to the whole car thing i have a 1jz 2.5l twin turbo and a friend suggested getting cams and a fuel rail out of a 2jz motor
Old 06-19-2008, 08:53 PM   #4
supramacist
supramacist's Avatar
It seems like I have herd that you can do that.
But once you start swapping cams you start throwing off the vafm.
I thought about gte cams on my ge. But to make it work you have to find a way to manipulate the vafm.
And that means maf-pro.
Tell your friend to hot rod his own shit. Before he helps you blow yours up.
Supradaddy has some very good points as well.
It will depend on years and all of that.
Try not messing with perfection until you get it tweaked right and see if you dig it.
You can't just mod these cars up. Especially with new cams.
Research research research.
Enjoy and Welcome.
Old 06-21-2008, 05:11 PM   #5
MWJon
MWJon's Avatar
alright, thanks
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
