Old 06-08-2008, 03:00 PM   #1
suprabahamut
Default speedodometer don't work
The speed Odometer don't work at all. Is it just the speed sensor or do I need to look some where else? What do I need to look at. It just had a motor swap , but the same motor went into it 7mge.
Old 06-08-2008, 11:33 PM   #2
suprabahamut
I was looking toady under the hood and the speed control device that has a cable going to the throttle is broken. I always thought it was only for cruse control. Does this have anything to do with the speed odometer? Or is it just the speed sensor on the transmission? Also I forgot to say it is a manual transmission.
Old 06-09-2008, 12:38 AM   #3
j3pz
speedo cable hooked up? did it break?
Old 06-09-2008, 12:55 AM   #4
SideWinderGX
SideWinderGX is on a distinguished road
theres three pieces to the speedometer cable: one long cable (connected to the dashboard), one short cable (next to the exhaust), and an adapter piece (fits into the transmission).
look underneath the car on the passenger side, right above the transmission brace (which the exhaust passes under). there should be an adapter piece right there, screwed into the tranny. this leads up towards the engine, connects to the shorter piece, and eventually connects to the longer piece.
take them apart one at a time and try to spin the little prongs sticking out of them by hand. if you cant spin them, replace it.
i had to replace all 3. the short cable is 10 bucks from toyota, the adapter and long piece are both 100 each.
the long cable requires you (no other way) to take out the dashboard. its not terrible to do though. the other two pieces take no more than 5 minutes to replace.
make sure none of the cables are hitting the exhaust, or are in a spot that will let them get too hot...it will break the cable again.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 06-09-2008, 11:31 AM   #5
suprakid91
suprakid91's Avatar
suprakid91 is on a distinguished road
i had the cable break off inside the housing almost at the bottom of the adapter piece. so would i have to get the 100 dollar one?
91' 7m-gte, sold
suprakid91 is offline   Reply With Quote
Old 06-09-2008, 03:51 PM   #6
SideWinderGX
if that piece that broke was supposed to be inside the adapter, then yes. buy it used if you can lol.
i would also test the lower and upper cables (its super easy) to see if they broke as well...you never know. just try and turn the insides...if they dont turn no matter what, its broken. theyre not too hard to turn.
my car:
Innovative LC-1 work as wideband/narrowband? mkiiisupra MKIII Supra 3 03-27-2008 11:48 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
