Old 05-16-2008, 03:08 AM   #1
panblackrose
panblackrose's Avatar
panblackrose is on a distinguished road
Default No Power At All: Suggestions...
I began by trying to replace my bad starter with a new one. Big mistake, seeing as my big hands wont fit in next to the second bolt. I had the first bolt off (the easy to reach one), and the two connections to the starter off. I put everything back so a shop could do the starter, and I have no power at all.
The motor is a JDM 7mgte with 40,000 miles on her. The body has 177,xxx and R154. I checked all of the fuses under the hood on the driver side, and the driver side kick panel, they're fine. I checked the cables on the battery, they're not too corroded and the terminals are alright. I will be replacing them both. I need to check the fuse box wire to see if it is corroded as well. My next step will be to connect a ground from the neg. terminal to a ground on the engine and see if I can get lights or something.
Any and all suggestions are welcome and much appreciated. I am combing through the Hanes Repair Manual, TEWD, and TSRM for schematics and other helpful tid-bits as well. I have read quite a few posts on the dead car issue, hence my course of action up to now. My last question is, is there a main relay or fuse I am missing? Everything worked just fine before I tried this and I only disconnected the battery, the two wires to the starter (the square plug and the signal wire), and the easier to reach bolt. I put them all back in properly...
NGHTY 89! No boost for you!
panblackrose is offline   Reply With Quote
Old 05-16-2008, 03:29 AM   #2
supramacist
supramacist's Avatar
Pull codes.
Cygnus X1 Home Page
Old 05-16-2008, 01:53 PM   #3
panblackrose
The car does not have power to even do that. The battery is fine. I'm going to run some cables from the battery to a better ground to see if I get anything...
Old 05-16-2008, 03:41 PM   #4
CyFi6
Are you sure your red B+ wire going to the starter isnt grounded out? If that was touching a ground in any way it would cause a lot of issues
Old 05-16-2008, 08:38 PM   #5
j3pz
yes make sure you didnt install the grounds on the starter or the B+ on with the grounds. the grounds get installed on the intake manifold
Old 05-16-2008, 09:41 PM   #6
panblackrose
That would cause the entire car to not have electricity? I will be taking a multimeter to her later... It looks like the 10 gauge wire going to the fuse box has become disconnected, when the rubber stretched and pulled apart the corroded wire. I wont know until tonight though.
As for the grounds, I rewired it exactly as it was before I touched it, but there were no grounds running to the manifold...
Old 05-16-2008, 10:12 PM   #7
supramacist
Ya it wouldn't work if you did this. he's probably right.
Edit. It doesn't have to be grounded to the mani.
It just seems to be s.o.p. .
Old 05-17-2008, 12:39 AM   #8
CyFi6
There are no ground leads off the starter, it grounds itself though the transmission bell housing
Old 05-17-2008, 02:15 AM   #9
j3pz
i only say the mani cause thats what ive always heard. but realistically no it doesnt have to be grounded there.
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
only starts by jump start ItsnotmySupra MKII Supra 6 04-27-2008 03:14 AM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
