Old 04-29-2008, 01:43 AM   #1
jdpartridge05
jdpartridge05 is on a distinguished road
try this...same thing happened to me i checked and tried everything but it was my alarm. i just had to d/c the battery for about a min then reconnect and it started.
jdpartridge05 is offline   Reply With Quote
Old 04-29-2008, 01:51 AM   #2
Factory alarm wiring cuts the starter... so it wouldn't be cranking. Good thought though.
Old 04-30-2008, 12:56 AM   #3
mustangtw5901
mustangtw5901 is on a distinguished road
Well, here is the latest update. I decided to start with checking the cam sensor and I think I found a problem. When I test the pickup coils for resistance as per the tsrm, I have all the correct readings except between plug terminal NE and G. Between G1 and G I had 174 ohms and between G2 and G i also had around 175 ohms. But when I checked NE and G I had an OL reading on the meter indicating excessive resistance or even an open. So I figure this can't be good and head to the local junk yard to find a cam sensor. Luckly I found one, but it looked in worse condition then mine. I bought it thinking I can make one good one out of both. The ohms checked ok on the junk yard unit so I swaped the internals into my housing. I am going to test it out tommrrow and I'll let you all know how it goes. If it still dosent start, then I guess I'll move on to the ignitor. Do you all think that my problem with the cam sensor could prevent the car from getting spark? And also, now that the resistance readings are ok, can the sensor still be faulty? Thanks
mustangtw5901 is offline   Reply With Quote
Old 04-30-2008, 01:14 AM   #4
Wow, you really should have a code 12 and 13 stored in the ECU. I'm quite sure that no NE signal would kill the ignition sequence.
Old 04-30-2008, 01:47 AM   #5
mustangtw5901
Yes, I do have code 12 stored. I was able to check for codes after I got the problem with the ign 7.5amp fuse worked out and was able to get the computer back online. Thats another reason I wanted to start at the cam sensor first.
Old 04-30-2008, 05:01 AM   #6
supramacist
supramacist's Avatar
Talking
Exactly.
We should give you one of them fancy sm badges.
you could be..
toyota-supra.info/specialist tech to advanced product research and developement all things 7m series oil and lubricant code 51 fix'n fire in the
hole havin toyota-supra.info/ specialist badge.
I"m glad your back man
Makes me want to sing..., why do birds.
suddenly appear. Every, time. You draw near;
Need I go on
Old 04-30-2008, 05:15 AM   #7
Originally Posted by supramacist View Post
why do birds.
We drive Supras... hello? Birdcage? But yeah, in my case the bird's plenty happy where he lives and the rest are jealous.
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
