Old 03-23-2008, 11:15 PM   #1
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
Default Very low compression
i recently bought a 89' turbo and i ran a compression test to find out why its smoking. no. 1 cylinder has 50 psi while the rest are within spec. I poured some oil in no.1 and it jumped to 70 psi so im pretty sure its a bad piston ring. So i was just wondering what are my options. How hard is it to change piston rings myself or how much would a mechanic charge. Also would it just be cheaper to buy a new engine? I can get one for about 1k.
paulmicin is offline   Reply With Quote
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
