Old 04-01-2008, 12:25 AM   #12
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Bolts have heads on them, while studs do not. You use nuts on the top of studs.
I could have made clearance for the ARP bolts, but I didn't want to do any grinding while the head was on, and I sure wasn't going to pull it back off. So I just reused the stock head bolts.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
