Old 06-23-2005, 08:18 PM   #11
ddmcse
ddmcse's Avatar
start pouring cash into the car
pick your method : there are several options
i think i am going to go with the lexus afm /550 injectors
i am shopping for 550's right now and i have the AFM already i bought it along time ago just haven't gotten to that stage yet
this should raise my fco a few clicks before i go to this ROM upgrade
http://suprasonic.org/sonictech/techtom/
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-23-2005, 10:25 PM   #12
chris
Guest
Posts: n/a
i need to know how to get the car running right without errors if poss do i need to turn down the boost if so how dont want to spend loads of cash looking for a quick cheap fix if possible
cheers
Old 06-24-2005, 01:06 AM   #13
ddmcse
ddmcse's Avatar
a brick behind the gas pedal
My Supra KiXGaS
Old 06-24-2005, 01:33 AM   #14
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
^ :lol:
ahhh i knew it was one of those 30 somethings lol
yea you are hitting fuel cut, you can do the lexus 550 mod or buy a fcd
i would recommend the lexus and 550cc injectors mod rather than a fcd as some ppl have been stupid to install one of these and raise their boost way above 10 and blew up their motor and wondered why
you need to do one of the suggestions and get on a dyno and tune it... the lexus will raise fuel cut to about 20psi i think... i can't remember exactly where the fcd puts it
yes lower your boost 1psi or more... you will find you don't hit it as often if at all
just remember... the fcd requires absolute certainty that you have the fuel to supply your engine DYNO it and ensure you can run the boost you want and have the fuel... buy a fuel pressure regulator also
there will be a T1 or TE1, then jump that with E1
Pics of my build.
Do a diagnostic first!
