Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 02-10-2007, 10:01 AM   #91
Caliturbo88
Caliturbo88 is on a distinguished road
Originally Posted by IHateHacks
Yeah I wimped out and only torqued to 70 ft/lbs.
Its all or nothing... Just like ricky bobby says "If you aint first, your last"
Caliturbo88 is offline   Reply With Quote
Old 02-10-2007, 04:20 PM   #92
Kuban
Kuban is on a distinguished road
Really can't believe the weather I've been having here. It was 9 degrees F today with a -10 F wind chill. Can't get anything done with numb hands. I picked the perfect time to change a head gasket. Better now than to have to have the car down for the summer. Don't have to drive it in all the salt on the roads at least.
yea we had one day with -10, -30 with wind chill. im lucky i have a heated parking garage to work on shit lol, i think my oil return sprung a minor gasket leak.
Kuban is offline   Reply With Quote
Old 02-11-2007, 02:52 AM   #93
IHateHacks
IHateHacks's Avatar
"you got an elbow gutted out ?"
Nope, the TMS downpipe has the O2 housing built into it. The TMS downpipe bolts directly to the turbine housing, eliminating the stock elbow. Suprastore advertises a 20hp gain with an HKS dp and the HKS doesn't replace the o2 housing, you must use the stock one with it, so the TMS is obviously better. Plus the TMS is 3" mandrel bent stainless steel. I love stainless.
Kuban, remember turbo oil pipe nuts should only be torqued to 9 ft/lbs. And make sure the mating surfaces don't have any old gasket material left over, which is very hard to do since the studs get in the way of cleaning the surface.
Old 02-11-2007, 01:41 PM   #94
ddmcse
ddmcse's Avatar
Cool
did you used to hit fuel cut before ?
what are your plans for fco ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 02-16-2007, 04:40 AM   #95
IHateHacks
IHateHacks's Avatar
"did you used to hit fuel cut before ?
what are your plans for fco ?"
No.
Walbro 255lph.
Old 02-17-2007, 01:46 AM   #96
dcrusupra
dcrusupra's Avatar
Originally Posted by the driver
what a piece of crap just like the owner
I'm sorry, I don't quite understand....who was that post to?
New Rebuild
My CarDomain
Old 02-17-2007, 06:47 AM   #97
mrnickleye
mrnickleye's Avatar
Question
Don't feel bad. 'The Driver' has offered some decent info/help over the past week or 2.
perhaps he had a 'bad day'.
But, perhaps with this next week off, he'll do some reflecting, and recover.
Old 03-05-2007, 06:01 PM   #98
JMoses
JMoses is on a distinguished road
[QUOTE=IHateHacks]
I need a little help. I have every single sensor connector disconnected except one. It is the one that goes to the top of the R154 trans. There is no way a I can get to it. Its a 2 wire connector and its white. I think the wires are yellow and red, but I can't remember. It's not the speed sensor. I think it is the backup light switch. How do I disconnect it? Drop the trans? Anyone ever have this problem when doing a head gasket on a manual turbo car?
QUOTE]
I just put a new head gasket on my supra and that wiring runs over the top and then down the drivers side of your tranny. If I remember correctly there are bolts that hold it onto the tranny.
JMoses is offline   Reply With Quote
Old 03-05-2007, 06:15 PM   #99
JMoses
Do you have any more pics of your engine around the starter area. I have a couple of plugs on my wiring harness and I cant find out where they go.
Old 03-06-2007, 03:37 AM   #100
jfunez
jfunez's Avatar
QUOTE]
just cut the wires off and when you are done...splice them with weather tight but connectors....it'll work fine...
HTML code is On
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Head gasket repair Kuban MKIII Supra 9 07-20-2007 09:01 PM
