Old 06-05-2010, 05:03 PM   #21
joshtexican
joshtexican is on a distinguished road
Ok so when torqueing the head. Do I need to have the "TIMING BELT CASE" on the block already, before installing head? As shown below...
joshtexican is offline   Reply With Quote
Old 06-05-2010, 07:04 PM   #22
Bill UK
AEM EMS
Bill UK's Avatar
Wow Bill, love your posts.... Wanna take over the FAQ section?
Thanks for you kind offer cre but I don’t have your knowledge or patience, I must say, "since you’ve been around, this forum as certainly go up a few gears". Your doing a great job cre.
Old 06-05-2010, 08:24 PM   #23
Bill UK
AEM EMS
Bill UK's Avatar
If it’s off already put it back on before fitting the head, but its advisable to fit No2 timing belt cover after you’ve bolted the head down, the reason being " if you skim the head, the head will sit lower down and the bottom part of No 2 timing belt cover could foul the top of the ally timing belt case (as shown in your parts image)" If that makes sense. Never been an issue with me, but I suppose if you removed a large amount from the head and used a standard gasket the bottom part of No 2 timing case cover could need trimming down.
Old 06-06-2010, 02:43 PM   #24
joshtexican
Thanks BillUK, The motor is basically taken all apart, an I am assembleing it together. The timing belt case is off.
Your basically telling me:
Timing belt case to block,
Head to block,
Then Timing belt cover after head has been put on block
Correct?
Old 06-06-2010, 03:12 PM   #25
Bill UK
AEM EMS
Bill UK's Avatar
Yep ! Correct Josh
Old 06-06-2010, 04:55 PM   #26
joshtexican
Niice!! OK I gotcha.
Thanks a lot, my complete gasket kit will be in tomorrow. I will then put the gaskets that go to the timing belt case so I may put it on. Then Bolt head down.
HTML code is On
Bolts? Studs? Blackdog MKIII Supra 9 01-12-2010 06:42 AM
Arp Head Stud Torque Settings!?!?!?!?!? papaleach MKIII Supra 2 11-22-2006 08:20 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
Torque Specifications (ARP Head Studs)??? Dejvid1785 MKIII Supra 5 03-06-2006 02:59 AM
