Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 10-10-2008, 11:30 PM   #20
Tateslikeink
Tateslikeink is on a distinguished road
Originally Posted by suprra_girl View Post
Had a similar problem, when throttling it would overheat but as soon as i backed off/decelerated it would cool down again, I was leaking between combustion chambers. Have you done a compression check?
Yea, the numbers were all over the place. From the 6th cylinder to the 1st everything was weird. 1st was 120 2nd.. i can't remember.. 3rd.. i can't remember, 3rd 145, 4th 155 6th 160. How would one go about fixing this issue if it was a leak between combustion chambers?? Because thats kind of how it is... Except, if i turn the car off, then start it again, its at normal temp.
Tateslikeink is offline   Reply With Quote
HTML code is On
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
suddenly overheating... how bad? sd88supra MKIII Supra 3 06-21-2006 10:21 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
