Old 12-22-2006, 02:32 AM   #1
84 celicasupra
84 celicasupra is on a distinguished road
i had the same problem with the fuel line connectors.. i used to big adjustable wrenches and broke them loose pretty easy
84 celicasupra is offline   Reply With Quote
Old 01-04-2007, 04:42 AM   #2
elsleepster
elsleepster is on a distinguished road
Okay....The Holidays are over and I finally got back to work on removing the tank. The tanks out, waiting for the pump and I'll let you know how it turns out.....
elsleepster is offline   Reply With Quote
Old 01-06-2007, 02:37 PM   #3
84 celicasupra
while you have the old pump out hook it to a 12v battery and see if it comes on,if not its bad,if it does then your problem is elsewhere..just do that before you go through all that trouble of replacing it and putting tank back in only to find out it still doesn't work
Old 01-06-2007, 08:53 PM   #4
elsleepster
Okay, I'll test it
Old 01-08-2007, 02:45 PM   #5
elsleepster
Talking
Well I didn't test the old pump, figured I'd replace it with a new one since I already had the tank off. Anyway, I got everything back on and it started right up!
Thanks for all your help and suggestions.
Old 01-12-2007, 12:13 PM   #6
84 celicasupra
well,glad to hear you got it running!! you are very welcome! glad to have been able to assist you. dm
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
starting problem Supraman MKIII Supra 8 09-26-2006 09:53 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
i have a starting problem johndawn MKIII Supra 4 02-16-2006 01:16 AM
