Old 10-03-2013, 04:59 PM   #1
iJaxonMkII
iJaxonMkII is on a distinguished road
Question 5g-me questions
I for my 16th b day got an 84 celica supra mk2 with a 5g-me no turbo motor......it is an automatic.....CAN I PUT A TURBO ON IT....or do i need to go with the 1jz???!!!
iJaxonMkII is offline   Reply With Quote
Old 10-10-2013, 05:27 AM   #2
The 7M-GTE would be an easier swap than the 1JZ. While you can most definitely turbo the 5M I don't recommend it... There's a lot more to it than just strapping a turbo on. If you have no experience with swaps or significant engine mods you should probably spend some time with it in its stock form and learn the basics first. I'll let the MKII folks cover the rest as far as the 5M and supporting mods go.
Old 10-14-2013, 03:19 PM   #3
it is called the: 5MGE and yes you can put a turbo on it. if you don't know much about turbo chargers or engines in general i suggest driving it the way it is and enjoying it or selling it and buying a honda accord.
Old 10-17-2013, 06:06 PM   #4
iJaxonMkII
oops sorry for the typo, but ive always been into tuners and used to work at a shop with my dad i was just looking for the easiest and most effective route for performance with the supra....il check with the 7m-ge
Old 10-17-2013, 09:36 PM   #5
7M-GTE (turbo), not the 7M-GE (non-turbo).
Old 10-18-2013, 12:17 AM   #6
The cheapest thing you could do in order to increase power, would be swapping in a 7mge or 7mgte supra engine. The power increase would be moderate nothing mind blowing, but if done correctly can be vary reliable. Even a 7mgte swap can cost thousands. And at 16 I doubt your income is consistent. A j series conversion is not for novice mechanics.
I myself have been working on an engine swap for 2 years, unless you make 30 dollers an hour it's difficult to put money aside for this type of project.
I am sure it's not the slam it in response you were looking for, I wouldn't want you to get over your head.
Old 10-18-2013, 05:54 PM   #7
iJaxonMkII
thanks for the input but its going to be a over the years father son project deal
Old 10-20-2013, 01:08 AM   #8
well if money is no object pick up a 7mgte j series or v8 like the 1uzfe do lots of research and check out celicasupra.com there is lots of people with the same car doing all sorts of stuff.
Old 10-21-2013, 05:31 PM   #9
iJaxonMkII
THANKS ill check that website out
Old 10-24-2013, 12:32 PM   #10
have you decided on an engine yet? make sure to check out all the 1uzfe and j series swaps on celicasupra.com there is even a 5L v12 swap on the forum there somewhere.
Tags
5g-me, automatic, supra, turbo
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
