Old 05-05-2012, 04:36 AM   #1
floridamtbiker99
floridamtbiker99 is on a distinguished road
Default Low idoling missing.
At about 500 to 600 rpms, it sounds like it is missing. It stall every now and then.
I replace the air filter that is when it started. I notice my plastic intake from the air filter box to the throttle body, some are cracked.
Also I am have problems of overheating, I thought it was a head gasket but no water in the oil, no oil in the antifreeze, no white smoke or water out the tail pipe.
Any suggestions?
floridamtbiker99 is offline   Reply With Quote
Old 05-08-2012, 03:37 PM   #2
check your intake piping for leaks as well as vacuum lines. it would not hurt to throw a timing light on it.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=10
Old 05-08-2012, 05:55 PM   #3
floridamtbiker99
Default Ok, Now what
My plastic intake is cracked and brittle.
Any idea of how to fix it or try to find a use ones?
Old 05-10-2012, 01:48 AM   #4
i know where to buy an aftermarket one...
other than that black electrical tape and proper hose clamps to extend life.
Old 05-11-2012, 12:08 AM   #5
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Try ebay or your local craigs list for a part out. The toyota number for the Turbo Accordian Hose (AFM to Turbo Housing) is 17882-42012 if yours is a turbo. You can use black silicone as a temporary fix once things are in place. May rip again on removal. Let it cure before starting. Silicone can dammage the O2 sensor.
Old 05-11-2012, 02:10 AM   #6
you should really fill in your sig. or user CP so we know what kind of engine you are running...
Old 05-26-2012, 08:45 AM   #7
floridamtbiker99
Default How do I know what engine I have.
All I know for the moment it is a 1986 (not a 1986-1/2) supra with a stock engine.
Old 05-30-2012, 03:20 AM   #8
any luck with finding new piping??? santa may have some...
Old 06-07-2012, 04:08 AM   #9
mechrider89
ya mine idles low as well but I think I found my problem:
My whole intake system looked like that!
plus my ignition system is in desperate need of maintenance, so that's another place to check out for your problem.
doing a 7mgte swap.. can you tell me what im missing? LOL ochowdero MKIII Supra 9 02-16-2012 07:33 PM
89 supra turbo missing after warm Rob1 MKIII Supra 10 02-15-2011 03:55 AM
Missing VIN from 1989 MKIII SupraSleuth Non-Generation Specific Questions 8 09-14-2008 08:57 PM
engine is missing and fluttering tonystarks MKIII Supra 5 06-08-2006 06:28 PM
Missing Fuse?? kewlcoconut MKIII Supra 7 10-17-2005 02:29 PM
