Old 04-06-2012, 10:19 AM   #1
floridamtbiker99
floridamtbiker99 is on a distinguished road
Default Help!!! Over heating
IT over heated numerous times yesterday. I pulled over to let it cool.
I bought new hoses, raditor cap, thermostat, flush kit, oil, oil filter, air filter, spark plugs.
I assume the theromstat is where the top hose goes into the engi80'sne.
Can anyone confirm it???
I have a old timing light from the 80's.
How to do time my 1986 (like a 1985 model).
I learn real quick at the parts store to ask for 1985.
Does anyone have a pdf file of an owner's manual and tear manual.
Thnak you in adavance.
Daniel P. Yoder
floridamtbiker99 is offline   Reply With Quote
Old 04-06-2012, 09:49 PM   #2
floridamtbiker99
Just found out no thermosat was in the car. now which way does it go?
Old 04-07-2012, 08:36 AM   #3
http://www.cygnusx1.net/Supra/Librar...Section=CO&P=6
Old 04-08-2012, 05:24 AM   #4
floridamtbiker99
Lessons learn with my car....
When I got the autoparts store like Advance auto, I have to ask for parts for a Toyota Supra 1985 not 1986. The 1986, they give me 1986-1/2 Supra parts that way different.
Right now I am flushing out my cooling system, as require drive with the flush system for about 6 hours.
I have another question. I will be on another thread about bvsv (broke the plastic). Do I really need it replaced? I just bypass it for now.
Old 05-03-2012, 05:13 AM   #5
floridamtbiker99
Now is it overheating witha theromstat in it. It is a stock one at 195.
Someone on this site or another forum stated that you have to put the plastic pan underneath for proper cooling.
Is this true?
Old 05-05-2012, 10:27 PM   #6
floridamtbiker99
Default Found out it is the clutch fan
Replacing it with a electrical fan possible gain of 10 hp.
Old 08-08-2012, 03:29 PM   #7
floridamtbiker99
Default Could be a head gasket or a radiator?
I have a 16" and 10" on the radiator now and still is over heating.
I replace the water pump, theromstat (165 degree). Still over heating.
The next thing is a radiator.
If not I hear that the head gasket gets a pin hole in it and all the hot gas boils the fuild.
Not oil in the coolant, and no coolant in the oil.
I am still puzzled.
Suggestions if possible.
Old 08-11-2012, 04:23 PM   #8
depending on how many miles are on your car, you may be looking at head gasket problems.
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=18
check under your oil cap for milky oil. and check your rad for oil, and get a compression check:
http://www.cygnusx1.net/Supra/Librar...Section=EM&P=6
if you are under 128 psi in any cylinders it needs replacing, and if any cylinders psi differ over 14 psi it also needs replacing.
beware of a cracked cylinder head. its happened to me.
Turbo and Heating Questions from a Beginner wood MKIII Supra 2 10-31-2011 06:38 PM
over heating CanadianBak'inSupra MKII Supra 2 05-29-2010 05:12 PM
over heating problems, need help turbo_mk3 MKIII Supra 5 01-08-2009 05:04 AM
Help! Losing water and over heating, but no dripping?!?! Moses76 MKIII Supra 5 04-06-2008 12:32 AM
Heating problem Lee MKIII Supra 3 10-04-2005 11:50 AM
