Old 12-04-2011, 10:14 PM   #1
Default new 5m build!
5mge for my friends cressida, gona start by washing the block.
going new bearings piston rings, new seals and gaskets ALL round, new w58 shifter bushings clutch.
block is going to be blue or black.
eventually i want to buy some intake upgrades as well as maby a header and cams.
if it still is around MS injectors and tires.
suggestions??? ideas?? open to anything just brainstorming right now...
Old 12-09-2011, 01:05 PM   #2
my pistons have seen better days and i was starting to wonder if oversized pistons was the right path for me, but i am not sure as to availability on 5mge pistons.
seen some on a parts list .5mm over for almost 60$ a piece.
Old 12-10-2011, 03:42 AM   #3
87hilux7mge
87hilux7mge's Avatar
woof, 60 a piece? to hell with that... ive been checking around on the net and havent found much better. not for over sized tho.
do they just have some carbon build up or are they chipped/pitted?
if its just build up, give em an acid bath. theyll be fine. if they are chipped or pitted, id look into some new ones and see if you can get away with just a hone. or take it too the shop and sometimes they have rebuild kits that you and it cant get. had them do that with my buddies 420a from his eclipse. whos ever heard of a .030 overbore for an import? not me, but they had the pistons, rings and everything.
hell, 6m the bottom end.
Old 12-10-2011, 05:10 PM   #4
there is noticeable scratching below the rings, going to see if i can just have them cleaned up maby polished.
i found lots of pistons on this site:
http://www.suprasport.com/Wiseco-Pistons_p_766.html
this particular set seems to come with rings and wrist pins and even the option of standard or .020 or .040 over sized for a whopping 700$ and im sure thats without shipping...
on a side note i found cams:
http://www.gude.com/Products/camlist.php#toyota
head down to the bottem and there they are....
Camshaft 82-88 Toyota Cressida / Supra DOHC 6 Cyl – 5MGE
PART NO: TYCS03
DESCRIPTION: Pulls from 400 to redline.
POWER BAND: 3800 R.P.M. to 7600 R.P.M.
IDLE: (Good)
SPECIFICATIONS: Intake: LIFT – 0.272 DURATION – 268
Exhaust: LIFT – 0.272 DURATION – 268
i sent an email asking for cost with shipping..
Old 12-10-2011, 06:24 PM   #5
got a reply from gude.com:
Spencer the 5mge cams 540.00 plus 250.00 core deposit which will be returned at the time receive your old cams back, shipping is around 80.00 you will need to mill the cam towers to match the cams thanks bill
Old 12-11-2011, 08:02 PM   #6
87hilux7mge
hmm, thats alotta dough. cuz the machine work to head will add up quick. but itd prolly make for some sick power from a 5m.
do i hear that magical exhaust note from a high revving inline six?? yes i do, haha.
if you got the dough then do it, id love to see it.
Old 12-12-2011, 01:30 AM   #7
na this 5m is for my buddy. ill get another one after xmass maby and use a 7m bottem end with 5m pistons and 5m head.
Old 12-14-2011, 01:37 PM   #8
got the block painted up nice.
ordered gaskets for the whole engine, online i priced a toyota set for 300$ with shipping, lordco offered me 180$ for a decent brand.
Old 12-23-2011, 02:48 PM   #9
some pictures
ive got more work done since but im saving the pics for further progress
Old 12-23-2011, 07:25 PM   #10
87hilux7mge
Lookin pretty sick man!
build sheet/prices, forgetting anything? 87supra7mgte MKIII Supra 22 10-17-2011 07:40 AM
My First Build Cameroonski MKIII Supra 7 01-04-2011 11:42 AM
