Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 06-26-2006, 05:54 PM   #1
SupraSaver87
SupraSaver87's Avatar
Exclamation How to change your oil
My Rant: Ok, well I just finished changing the oil on my MKIII....don't ask, just don't freakin ask.....I hate Japanese designers...they should have "Big hand" gloves when designing stuff. anyways.....
First: Raise the car up, I used two jack stands just aft of the front tires, on the main support rails under there.
Second: Look for the oil pan, then remove the bolt that is in there.
NOTE: Do remember to loosen it with a ratchet, then put a pail in the way to catch the low velocity stream of oil, then unscrew the bolt the rest of the way with your fingers.
Third(And the hardest): Remove oil filter, and replace with new one.
NOTE: There is a reason I said that the third step is the hardest....SPACE!!! Or lack there of. You WILL NOT have room to get an oil filter wrench in there, so if it is on there pretty good, call you good ol friend bubba over, and let him reef on the thing for a while.
Next, once the oil filter is removed, you now have to lift the filter OVER the brace (You'll know what I mean once you get under there), down over some other stuff, and it will drop down about 6" - 1 foot later.
Well this is still general, but it should help ALOT of ppl.
I opt this get "sticky'd", and if it does, I'll re-write it to sound better, and it'll be more in depth than. It took me about 1 hour to figure all of this out, and I only gave myself 1 hour, and about 8 minutes to do this before I had to be at work....lol.
Old 08-01-2006, 08:08 PM   #2
supra_91
supra_91's Avatar
the oil filter is easier to take off from the top of the car
Old 08-01-2006, 11:27 PM   #3
Toyotafanatic
Toyotafanatic's Avatar
Toyotafanatic is on a distinguished road
I use a leather belt for taking out my oil filters, way easier than that tool, on the Supra at least.
BOOST IT!
Toyotafanatic is offline   Reply With Quote
Old 08-02-2006, 05:57 PM   #4
supra_91
supra_91's Avatar
the filter tool i use has 3 fingers on it that attaches to a rachet and it really grabs the filter
Old 08-02-2006, 09:06 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Tried most wrenches over the years, the one I would recommend is No 1 in the photo below, its called a cap wrench, it has a 1/2 inch or 3/8 inch square hole in the end suitable for the standard extension wrench bar,. I got mine in the UK .for about ?3 GBP.
If it helps the Toyota Filter measures 74mm with fourteen flats.
No 2 photo is a K&N filter with built in hex nut shape on the bottom. I haven’t tried them since the cap wrench does the job.
Old 08-03-2006, 01:16 AM   #6
Cool
this is one reason why they sell oil filter relocator kits
Old 08-04-2006, 01:24 AM   #7
supra_91
supra_91's Avatar
those K&N oil filters are $12. i buy the fram no slip ones for $5
Old 08-19-2006, 08:13 AM   #8
Wink Few Tips
Best to have engine warm first, makes the oil flow easier. Best to use a new gasket on the drain plug. Make sure the old gasket comes off the pan, and the surface is really clean.
Make sure the old filter gasket comes off the block, and the surface is really clean.
Make sure you put some new oil on the new filter gasket (use your finger to apply).
At home, I drive the car up on the edge of the curb, with the 2 driver's side tires, so I can slip under easy, and the drain hole is on the low side.
Old 04-19-2009, 01:39 AM   #9
supertoyota
supertoyota is on a distinguished road
Question Quick Oil Drain Valve
Does anybody know about the Quick Oil Drain Valve?
www.qwikvalve.com
I will probably get one for my vehicle. However, if somebody has already installed and give me more info for the item, I would really appreciate it.
supertoyota is offline   Reply With Quote
Old 04-19-2009, 06:24 PM   #10
Bill UK
AEM EMS
Bill UK's Avatar
Not something I would recommend fitting, just imaging going over a speed bump and knocking that tap off. I don’t think the engine would appreciate it.
Change the climate cntrl color? XtreeX MKIII Supra 6 05-10-2008 01:54 PM
Speedo is out, what do I change? linuxgurupodboy Non-Generation Specific Questions 0 05-15-2007 12:07 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
