Old 03-29-2007, 03:47 AM   #1
kidthunder650
kidthunder650 is on a distinguished road
Default my 87 supra just baught it.
i want to fix this car up. its not running right now, well it runs but just barely.
on hopes and dreams. haha.
here we go,
i got the 90's taillights to install as soon as the motors running to my spec.
its got a rebuilt 7mgte and new turbo, its just dumping fuel right now so it wounlt run.
kidthunder650 is offline   Reply With Quote
Old 03-29-2007, 04:12 AM   #2
dcrusupra
dcrusupra's Avatar
Can you see where the fuel is coming from?
New Rebuild
My CarDomain
Old 03-29-2007, 05:14 PM   #3
kidthunder650
i dont know why. its dumping it in the engine making it run way way way rich.
Old 03-29-2007, 06:01 PM   #4
IHateHacks
IHateHacks's Avatar
Did you buy the car like that or did you install those aftermarket parts?
I noticed a couple things. 1 you are missing the upper timing belt cover which it may look "cool" without it, but it will drastically reduce the lifespan of your timing belt because all sorts of bad stuff gets in there like sand, water, "debris". 2 you are missing the CPS dust cover, again, letting unwanted contaminants get into the CPS. You'd be amazed at what flys around the engine bay while driving. Thats not something you are going to want to replace seeing it is a cool $500 from the dealer. The dust cover and seal is less than $5 total. Do the math.
I like the exhaust manifold you have on there, is it a stock jet coated one? Or is it aftermarket?
What are your adjustable cam gears set to? I would put them to 0 if they aren't already, and then I would set the ignition timing to 10 degrees BTDC and start from there. If you don't know how just ask.
Old 04-17-2007, 05:00 AM   #5
BlackDynamite
BlackDynamite is on a distinguished road
Possible timing if it won't run right...or you can do like my friend did when he did the sr20det swap for the 240sx and have both a broken/faulty o2 sensor and MAF....made him run RICCCHHH and wouldn't let him rev above 2400 rpm...Dunno if this happens on toyota's...worth a check...
BlackDynamite is offline   Reply With Quote
Old 05-10-2007, 02:35 AM   #6
carwheel
carwheel is on a distinguished road
Just keep up the good work. It'll take some time, though.
____________________
Verns
2005 Toyota Tundra Accesorios - Tundra 4x2 06 Catalog by Toyota Motors
carwheel is offline   Reply With Quote
Old 06-01-2007, 02:58 AM   #7
zooooom
zooooom is on a distinguished road
Hope dangles on a string! Fix it, and drive it like crazy!
Marie Jane
zooooom is offline   Reply With Quote
Old 06-11-2007, 06:51 AM   #8
4ageBT
4ageBT's Avatar
4ageBT is on a distinguished road
Sleeper. I love the rims.
just a new paint job the that car will shine perfectly.
Autoparwarehouse blog..
4ageBT is offline   Reply With Quote
