Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Shops & Part Reviews
Old 06-25-2005, 11:25 PM   #1
Jeriko Suratos
Guest
Posts: n/a
hey dudes, i went to suprastore.com and found the kit for you. the store has hp kits that go up to 1200hp but cost over 30,000 dollars. i do not know if it is fraud or not
Old 10-03-2005, 02:35 PM   #2
Soggie
Soggie is on a distinguished road
Default 1000 hp
I have read many of the replies to this question. Let me say that I have 2 supras one of which is 700rwh and the other is being built by a race car team in FLa which will break the 1000hp mark. The race teams are running between 1200 and 1300 rwhp. The cars take daily maintenance and much replacement of worn parts. You don't just say you want 1000 rwhp lightly. It takes a COMPLETE reworking of the entire engine. from the long block to the spark plug cover. I will tell you you better have 80K plus to put into the engine as well. Just replacing the short block the injectors and exhaust won't cut it. In my 700whp car i was supprised at how much it took to get a few extra horses once you passed the 500 hp mark. You need a complete package including the injectors all of these items work together to get the max performance. Good luck with your goals even if you don't make it it will be fun trying.
Soggie is offline   Reply With Quote
Old 07-01-2006, 07:10 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by disturbednitehawk
hey,im new to this forum and to the car world..this will be my first modded car.. im about to get a 98 supra or a rx-7 but im leaning towards the supra (hot car) and i want it at least 800 hp..1000 will be GREAT! so..do anyone know the parts i could get to get started on my way to 1000hp?...
Sorry I missed this thread (in Shops & Part Reviews?) ...but either way 800hp (680rwhp through a 6spd) is relatively simple with a Mkiv TT (2jz-gte). All you need is a fuel system with 680cc injectors, a mid-size (eg. 67mm inducer) single turbo kit, fmic, race fuel, and some supporting electronics (eg. MAP ecu or eManage). If it's a 6spd, you'll need to upgrade the clutch as well (eg. RPS twin carbon-carbon).
1000hp (850rwhp through a 6spd) isn't much harder, but you'll need larger fuel injectors (850cc), aftermarket cams (eg. HKS 264s) a bigger turbo (eg. 72mm), and an ignition amplifier (eg HKS DLI).
I'd like to stress that there is no need for a 'built' engine at this horsepower level, unless you're talking about 1000rwhp. A bone-stock 2jz-gte block&head will reliably support 800hp and 1000hp as-is.
Fwiw, I'd recommend you also include a set of wider-than-oem rims (& wider tires of course) in your shopping list, or all that 800hp+ will do for you is burn up tires. Again, wider is necessary for traction. For diameter either 17", 18" either is okay (you could even go to 19s in the front, but rears should be 18" or less to allow for a taller sidewall (=traction). Specs must be at least 11" wide in the rear, 9.5" wide in the front.
Are you looking for a 6spd or auto?
Life begins at 30psi.
Old 07-01-2006, 11:18 PM   #4
neoman
neoman is on a distinguished road
These two supras are for sale in japan currently, the blue one is bored up to 3.2 the red one is bored out to 3.1. both are over 1000 bhp
Name:	supra 1000 eng.jpg
ID:	340   Click image for larger version
Name:	supra 1000 inter.jpg
ID:	341   Click image for larger version
ID:	342   Click image for larger version
Name:	supra 3.2 eng.jpg
ID:	343   Click image for larger version
Name:	supra 3.2 int.jpg
neoman is offline   Reply With Quote
Old 07-01-2006, 11:21 PM   #5
neoman
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
quesdtions about 1000hp macman Non-Generation Specific Questions 1 07-09-2005 08:40 PM
1000hp parts slickjester201 Shops & Part Reviews 1 04-02-2005 09:03 PM
