Old 07-01-2006, 07:10 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by disturbednitehawk
hey,im new to this forum and to the car world..this will be my first modded car.. im about to get a 98 supra or a rx-7 but im leaning towards the supra (hot car) and i want it at least 800 hp..1000 will be GREAT! so..do anyone know the parts i could get to get started on my way to 1000hp?...
Sorry I missed this thread (in Shops & Part Reviews?) ...but either way 800hp (680rwhp through a 6spd) is relatively simple with a Mkiv TT (2jz-gte). All you need is a fuel system with 680cc injectors, a mid-size (eg. 67mm inducer) single turbo kit, fmic, race fuel, and some supporting electronics (eg. MAP ecu or eManage). If it's a 6spd, you'll need to upgrade the clutch as well (eg. RPS twin carbon-carbon).
1000hp (850rwhp through a 6spd) isn't much harder, but you'll need larger fuel injectors (850cc), aftermarket cams (eg. HKS 264s) a bigger turbo (eg. 72mm), and an ignition amplifier (eg HKS DLI).
I'd like to stress that there is no need for a 'built' engine at this horsepower level, unless you're talking about 1000rwhp. A bone-stock 2jz-gte block&head will reliably support 800hp and 1000hp as-is.
Fwiw, I'd recommend you also include a set of wider-than-oem rims (& wider tires of course) in your shopping list, or all that 800hp+ will do for you is burn up tires. Again, wider is necessary for traction. For diameter either 17", 18" either is okay (you could even go to 19s in the front, but rears should be 18" or less to allow for a taller sidewall (=traction). Specs must be at least 11" wide in the rear, 9.5" wide in the front.
Are you looking for a 6spd or auto?
Life begins at 30psi.
