Old 05-29-2005, 07:41 AM   #21
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
i c. go on what else? im hungry for info.
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 05-30-2005, 09:10 PM   #22
monkihead
monkihead's Avatar
i guess somethings wrong with my car then, regarding oil pressure. at startup she idles at 1500 and a lil over 40psi. after warm up idles at 650 right under the first hash mark...hmmm
monique- better off dead
Old 05-30-2005, 10:28 PM   #23
KingDiamond
well if you have your owners manual, it will actually show you the different ranges that are safe for what rpms its running at, and i believe it mentions when you first start it , when its cold, the pressure is gonna be higher.
Old 05-31-2005, 12:39 AM   #24
also the car shouldn't be idling at 1500rpm cold, check your ignition timing, also is probly why oil pressure is higher than normal
Old 05-31-2005, 03:05 AM   #25
Guest
Guest
Posts: n/a
but its distibutorless? can you adjust timing on these? i thought it was a maintenance free from timing?
Old 05-31-2005, 04:36 AM   #26
distributorless
have you got a 1jzgte?
if you don't have the above engine you have a cps or distributor
Old 05-31-2005, 07:26 PM   #27
monkihead
monkihead's Avatar
i have a cps
Old 06-02-2005, 02:17 AM   #28
jza80 Supra C-I TT
whats cps
is a 1jzgte a supra engine? is it a mk3 is that why it sounds so familiar? what do all the numbers and letters stand for?
Old 06-02-2005, 04:03 AM   #29
1JZGTE = 2.5L twin turbo 280hp stock @ the flywheel and comes in mk3's chassis known as JZA70
mother engine to where the 2JZGTE was born
cps = cam position sensor (distributor basically but electronic)
Old 06-02-2005, 04:05 AM   #30
jza80 Supra C-I TT
what are cams exactly? is it older versions of pistons? whats the difference between a twin turbo and a twin cam?
