Old 05-25-2007, 01:50 AM   #1
IHateHacks
IHateHacks's Avatar
Damn I wish I saw this thread sooner.
NGK are the best plugs you can buy.
MSD are the best wires you can buy, they are better than NGK wires.
MSD wires have less than 50 ohms of resistance per foot, try to find a wire that has less resistance than that. A stock wire has 1000's of ohms of resistance.
Beck and Arnley? Those are generic cheap parts store crap. You got hosed for $60. JSCspeed.com has MSD wires in stock and are $90.
Stay far away from bosch spark plugs. Go with NGK only.
Old 05-25-2007, 11:55 AM   #2
scruffboy
scruffboy's Avatar
Thumbs up Hi IHH
Thanks for the input. I got the NGK plugs, but you think I got hosed on the wires, huh? Are they absolutely horrible, or can I run em for a little while? I was in a rush as to getting parts as I want this done by Memorial Day weekend. I'll see how this works, hope it doesn't give me any problems. Also, I called the Toyota Parts shop because I need that 90o bent hose that hooks right over the intake. Mine is rather worn (torn and cracked, and unless I snug it up real tight it lets in air). They want $80. Can I replace this with a simple pre-bent piece of hosing? It looks about 3 to 3 1/2 inches diameter. Whatcha think? Thanks for the help guys!
Scruffboy
Old 05-26-2007, 03:33 AM   #3
mrnickleye
mrnickleye's Avatar
Those beck/arnely wires will work ok, as you are N/A. I've been using Carquest wires for 3 years without a single problem.
I did go down to the speed shop and got some bulk MSD wire and ends for the coil to dist. I did this because the coil wire carries 6X the flow volume of current than each individual wire.
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
Oil around the spark plugs!!! TxSpeedBoy Non-Generation Specific Questions 11 02-01-2006 05:46 AM
